No because it is too dangerous. When you go into Airplane Mode, you literally turn everything off! Airplane Mode is only for being on an airplane. If you are using it a lot whilst not flying, you are not using it correctly.
Go to the phone main menu, select settings, and look for Airplane mode, press it. It should give you the choice of turning it on or off. Select off and you should be able to call and receive calls again.
go to the sound profiles in side the settings on that you will see a profile named as offline. click on it and activate it. its the airplane mode in the samsung
If you want to try a simple solution, Go to Settings, Wireless and Networks, then Turn on "Airplane Mode" wait until you see an airplane on the top status bar of your phone... then Turn OFF "Airplane mode" If that doesn't work, and you want to reset your phone, take it to the place you bought it or any place that is on your carrier.
Airplane Mode (Motorola CLIQâ„¢ with MOTOBLURâ„¢) NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active. To turn Airplane mode on or off, refer to the following: ---------------------------------------
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps: 1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps: 1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
To fix the problem and restore your connection
(turn OFF airplane mode), click "Menu," then "Settings," then "Phone
Settings," then "Airplane Mode," and then set the mode to "Off." Once
you turn off the airplane mode, your Samsung phone will function as
normal.
Do you mean the Airplane Mode? You can switch Airplane Mode off by pressing the center black button on the phone (for the Menu) then going to Settings & Tools and choosing Phone Settings. The first entry on the Phone Settings menu is Airplane Mode -- select it and choose Off, then hit the center button.
Then you can go into Sounds Settings on the Settings & Tools menu if you want to choose your ringtones and whether or not your phone vibrates. You can set the ringer volume by using the up and down volume buttons on the left side of the phone.
