I have a HDTV and I also use tivo for my DVR but I started noticing that my HD recorded shows are not coming in clear. When I play back the digital signal fades leading to a pixelated picture and in and out sound. How do I prevent this from happening.
Re seat the audio and HDMI board on your 804 and it will correct the issue. from the back its the HDMI is the TOP board on you left an the Processor is the vertical bord on the left running along the side of the receiver it connects to the main board, amp board, and HDMI board as well as the main panel via a wide ribbon cable. take the boars out and reseat it back in place. if you put a fan in side the unit it will help alot. these connector when they start going they get worse with heat keeit the unit cool. good luck
