Mod 590 ser m1025282 make year 1993
For a 1993 model, the problem is most likely a clogged inlet strainer on the solenoid operated valve on the back side of the access cardboard cover near the bottom of your refrigerator. If you take your model number to Searspartsdirect.com and you can order a new valve if the solenoid has finally stopped working.
Before to much troubleshooting, check the isolation valve where the water hose hooks up is open. It may be someone closed the isolation valve.
Hope this helps
