Question about Garden
Shut down engine
Switch turn to off can not shut down
  • Eugene Rounds Dec 14, 2014
    Hi Yaoting pang, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    In order to help you troubleshoot your problem I need to know the make and model of your mower and possibly the engine numbers too.
  • 1,169 Answers
The anti backfire solenoid sticking opening doesn't prevent the engine from shutting as you are killing the output of the coil. It does however allows extra fuel into cylinder and exhaust which can create that backfire sound that most experiences on normal shut. The grounding of magneto is what shut downs the engine which in this can be as simple as broken wire to a bad magneto coil.
Posted on Dec 15, 2014
    New Friend:
    Problem Solver:
  • 16 Answers
Most engines hav an anti backfire valve solenoid screwed under the carb bowl. This sometimes sticks due to ethanol gas. When you turn off the ignition, it closes the valve to let the engin run out of fuel. If it sticks closed the engine will not start. Sticken open, the engine will not shut down. It has a single wire going to it. When you turn on the key, you should get power to the solenoid. If you have power to it, then remove the solenoid and clean the needle valve and carb opening. Would be a good time to clean carb also. A good carb cleaner works well. Ethenaol added gas is a real culprit to carbs nowadays.
6ya staff
SOURCE:
My merc 40 hp four stroke shuts down immediatly after start up reves to 3000 rpm them shuts down
I had one that did this and it turns out it was the plug on engine that ran to dash switch had a corroded connector in it , vibration from engine made it shut engine off !! just like the key !! it would start right back up run a minute then shut off again !
Nov 08, 2016 | Cars & Trucks
Mow for 30-60 min.mower shuts down. Sometimes you can mow all day.start goin up hills mower will shut down,about the second or 3rd trip.what's the problem?
Don't know what kind if engine you have but many have low oil shut down float switches inside the engine..when operating on hills or side if hills too long the oil will flow to the low side and the low oil switch will pick it up as low oil and shut it down..look for a small wire attached to the crankcase it most likely is that low oil switch..the next time this happens try disconnecting it and tape the end if the wire..try starting and run on the hill..it should not shut Down..just remember it is a safety switch to protect the engine from damage from low oil operation.try running the hills where the oil runs to the wire side of the engine..won't trick the low oil alert...Good luck..
Aug 08, 2015 | Garden
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
91 honda accord fan stars when you shut off engine
There are two fan switches on that car;
The main one turns the fan on and off when the ignition is on and the car is running.
The second switch powers the fan if the ignition is off and the engine temperature is too high, to cool the engine off if it was just shut down.
It sounds like your main fan switch has gone bad and needs to be replaced since it's not sending any signal to the fan, while the engine is running.
Oct 22, 2012 | 1991 Honda Accord
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Engine cuts out when hot
every generator has an auto-shut down system that turns the engine off when over heated..u can dislocate the wire coming out of the engine and into the on/off switch...and then it till never shut off unless u tell it to....
but be carefull!!!!!!!!!!!!!:when u dislocate it...u r turnning off the auto-shut down system...so if the engine over-heats.. it will not shut down...
if u have any further questions email me at sal_kh_sab@yahoo.com
Jul 13, 2009 | Coleman Powermate Powermate 5000W...
When I turn the key to shut the engine down it
I don't think the starter solenoid is involved here. T
There should be a fuel shut off solenoid on the bottom of the carburetor which shuts off fuel when the ignition is turned off -- this is a safety feature as well as protection from damaging backfiring.
This fuel shut off solenoid could be stuck open.
There is a switch under the seat which opens and closes the solenoid depending on whether the seat is occupied. This switch as well as the ignition switch control the solenoid.
May 06, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Car wont shut off
Sounds like a bad ignition switch....Thats where i would start...
Sep 14, 2008 | 2000 Dodge Neon
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
