Unplugged,pushed control panel. Some numbers show and beeped a couple of times.
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
SOURCE: How to stop the beeper and reset the "code' light on panel?
The first thing to try
is a "hard reset". Unplug it from the power line for a minute, plug it
back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it, and please reply back with your model number so we can help you.
FOR ADDITIONAL SET-UP OR OPERATING ASSISTANCE
PLEASE CALL: 1-800-898-9020
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
SOURCE: setting time and getting numbers to work
Is your microwave a portable model so that you have access to the power cord? If it is, unplug the cord and leave it off for a few minutes. Then replug and it may reset. This seems such a simple solution, however, sometimes a simple solution is the answer. If your microwave doesn;t respond, I would consider the age and condition of it and consider replacement. Repair can be expensive and the price on these appliances is now quite reasonable. Good luck to you.
SOURCE: emerson microwave mw8115ss In from vacation and
The problem is the keypad "short in the membrane" or the microprocessor control board.
