Uniden DECT 6.0 Cordless Phone ID Logo
Olive Strauman Posted on Dec 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not the ringer volume - I want the sound volume increased. I can not hear what people are saying
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Uniden Master 102,366 Answers
  • Posted on Dec 13, 2014
Uniden Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428557
Points
622693
With many Uniden DECT 6.0 phones, pressing up-arrow during a call will raise the volume.
If this doesn't do it, please add a comment to this question and specify the model of your Uniden DECT 6.0 phone.
My uniden 6.0 cordless says silent mode on. I cannot hear my phone ringing' tell me how to turn the silent mode off.PLEASE DOROTHY
page 12 of the user manual
ringer volume for each handset( if you turn the ringer all the way down that particular ringer turns off)
when it happens---- in standby
press up to increase volume
7helpful
MY POWER MAX 5.8 SAYS THAT MY VOLUME IS OFF ON ONE HAND SET--HOW DO I TURN IT ON? THANKS EILEEN CARTER [email protected]
There are different ways to adjust the ringer and speaker volume on your handset. Please see your owners manual for model specific instructions.
On most single handset units:
Ringer volume: Press the volume up or down arrow rapidly to change the ringer volume.
Speaker volume: When talking on the handset press the volume up and down arrow to increase or decrease the volume.
On other models:
Ringer volume
In standby mode, press the volume up key or volume
down key on the handset or base to select one of three
ringer volume (Off, Low, or High).
Earpiece and Speaker Volume
You can select from among of six volume levels on the
handset, and ten levels on the base. Pressing the
volume up key or volume down key on the handset or
base during a call will change the earpiece or speaker
volume. This setting will remain in effect after the
telephone call has ended.
If you press the volume up key when the earpiece is at
the maximum volume level, an error tone sounds.
The error tone also sounds if you press the volume down key at the lowest volume.
Sergio
HOW TO ON THE RINGER?
Not sure which kind of cell phone you have? There must be setting on the phone to turn on the sound and the ringer. Just go the menu and turn it ON and make sure the Volume is not mute(increase the volume to the level you can hear the ringer) . Hope it helps , write the details if this doesn't work.
Regards,
Jan 03, 2011 • Cell Phones
My LG220C ringer volume starts at about 0 and slowly increases in volume as you wait. With the Speaker "on" it starts with a loud ring. What needs to be changed to start the ringer volume at my high...
i BELIEVE there is a setting I think in either your ringer volume or in your sounds or tones (sorry I cant be more specific but its been a ling time since I had a phone that even came with that option) that will give an option of ascending ring which it sounds like to me it is set to this you need to change that
My problem is ringer volume i cant when someone is calling
Hi, when a phone has a ringer volume problem, is either the ringer of the phone is weak and you can't hear when someone calls you or the volume of the ringer is yet at a very low level in sound.
You will need to check the volume settings of the phone if the volume is low so you can increase it to a high level.
If the setting of the volume is high, that means the ringer that a makes you hear when people call is weak and will need to be replaced.
Any further question or comment, you can pass it on as comment.
Take care.
2helpful
2answers
How to increase the sound
To increase the sound of your motorola MOTOZINE ZN5 cell phone.
You can increase the sound of your phone in three categories.
1. music volume,
2. ringer volume,
3. keypad tone volume.
To increase the music volume, you go to the multimedia, select sounds, once the song is playing then you click on the up button that is by the side of the phone. You can increase it to the volume that pleases you.
Further means to increase the volume of your phone is that you go to the 'menu', click on the 'settings', select the 'profile', select 'personalize', a page will show up with a list of data that can be changed on the profile, select the ringer volume, keypad tone or whatever sound you want to increase and increase it with the direction button pointing upward that is by the side of the phone.
To increase the keypad tone, from the home page, click on the up button that is by the right side of the phone, the volume of the phone will increase.
Take care
1helpful
Can't hear ringer
I had this same problem with my Blackberry. You should check the settings on your sound and volume for incoming calls and make sure you have a tone set. You can also find a way to amplify your ringtone by hooking it up to your computer. If you dont' hear anything at all, then check the buttons on the side and see if that increases the volume. Please rate my answer.
12helpful
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Backberry 7290 Ringer Volume
Click the PROFILES icon and set the unti to LOUD :)
10helpful
3answers
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
