They wont thread on I have not used filters before so I don't know if I need something to attach the filters to before I attach them they seem to be too small
Filters must be the right size for each lens. For example the 18-105mm kit lens that comes with most D-90 kits uses a 67mm filter. They thread into the main lens. It is always safer to put a clear or UV filter on your camera lens to protect the expensive lens glass. You can thread another type of lens onto it as easily as you can your base lens. Be sure and do not force a threaded lens filter onto your lens or you will damage the expensive lens. It should thread on easily and do not over tighten it.
