Want to add a second desk top computer to my home..was told by the cable company provider that i would have to.. add a second line $60 i s there any other way to add a second computer
SOURCE: want to use wireless without running cables
Do you have instructions for the router? They should be available from the D-link site. Connect the router to the computer with a network cable. Type cmd into your run box on the start menu then type ipconfig into the window that opens and note the IP address of the DHCP server, which should be in the form 192.168.x.1 and log into it by opening your browser and putting that no. into the address bar. This allows you to control the router and examine its settings. With the information you obtain it should be possible to connect the computer wirelessly, using the either windows wireless manager, which should be an icon near the clock, or the program that belongs to the wireless receiver.
SOURCE: i have a wireles belkin
go ahead and power everything down. wait a minute then plug in your router. once all the lights are steady power up your pc. once complete go to run, type cmd and enter. At the prompt type ipconfig and enter. ping your ip address.
SOURCE: I AM UNABLE TO ACCESS INTERNET THRU MY HYBRID APPLE MAC DESK TOP-
Go into network set up
a shared Internet connection using ICS (Internet Connection Sharing)
You can use Internet
Connection Sharing (ICS) to share an Internet connection among two or more
computers on a network. First, you need one computer, called the host computer, that is connected to the Internet and that
has a separate connection to the other computers on your network. You enable ICS
on the Internet connection. The other computers on your network then connect to
the host computer, and from there to the Internet through the host computer's
shared Internet connection.
If your computer is connected to a network, network policy
settings might prevent you from completing these steps.
On the host computer (the computer whose Internet connection you
plan to share):
SOURCE: is there instructions on how to add a second sata
yes there is pls. go to this link as it will give you the instructions on how to add additional SATA Hard drives.
http://www.wikihow.com/Add-an-Extra-Hard-Drive
