I have window 7 professional & someone told me I need to dowload silverlight, which I did, but I still only get a text box above the menu bar, rather than a small window
How do I get the Aero desktop experience?
The following editions of Windows 7 include Aero:
Aero is not included in Windows 7 Home Basic or Windows 7 Starter. You can find out which edition of Windows 7 you have on your computer by opening System in Control Panel.
The edition of Windows 7 you're running is displayed under Windows edition near the top of the window.
You also need to use a Windows theme to display Aero graphics. If you are using an Ease of Access theme, some elements such as transparency and thumbnail previews will not appear. To view which theme you are using, open Personalization in Control Panel.
The theme currently in use is highlighted.
The desktop screenshot might need reducing Click start "Control Panel." Click "Display" and then select the Settings tab in the Display Properties window. Use the slider bar under in the screen resolution section of the applet to change the resolution and click "Apply." The screen repaints at the new resolution. Click "Yes" to keep the resolution, or answer "No" at the prompt to revert to the original settings.
The taskbar is a central user interface component within the Microsoft Windows 2000 operating system.
Located along the bottom of the screen by default, it includes the "Start" button, provides one-click access to all open programs and contains a collection of utility icons and the system clock in a section called the Notification Area.
Windows 2000 gives you the ability to adjust the behavior of the taskbar in several ways.
After you know where to find the proper menu item, performing this task takes only a few clicks.
Right-click on an empty area of the taskbar and select "Properties."
Click the "General" tab located along the top of the resulting dialog box.
Check the Always on Top box if you want the taskbar to appear above all other items on your screen.
Check the Auto Hide box if you want the taskbar to disappear into the bottom of the screen when you move the cursor away from the taskbar.
Check the Show Small Icons in Start Menu box if you want to enable this behavior.
Check the Show Clock box to show the system clock within the Notification Area at the right edge of the taskbar.
Check the Personalized Menus box if you want the "Start" menu to show the items you use regularly and hide the items you don't.
Click "OK" to confirm your changes.
They take effect immediately.
Hope this helps
