NorStar M7310 Corded Phone Logo
Posted on Jul 06, 2009
Cannot change greeting when we are out of office. M7310 phone
M7310 phone - change greeting
A
Anonymous
Which greeting is it? If the AA greeting...try this.
But listen before you record, to make sure you are recording the correct thing.
http://dstech1.com/how-do-i-change-the-auto-attendant-greeting-on-my-nortel-voicemail/
Norstar M7310 I cannot get the greeting from the last admin off of this phone. My greeting plays when the call comes in and it directs callers to the extensions, but after my greeting the old greeting...
The greeting is from the voice mail not your phone.
Logging In To a Mailbox From Your Own Extension
1 - Feature 981
2 - Pswd: Dial 4-digit password (default is 0000)
Follow prompts to change your greeting. They are: ADMIN, then GREET and then RECORD.
When done hang up or push RLS. I have installed several of these systems.
1helpful
Trying to listen to voicemail grettings.
If your talking about listening to the individual mailbox greetings without calling into the system then you could use feature 980 (leave message)
enter in the mailbox number you want to check and press ok.
Can I change my MAIN Admin greeting from home if there's a storm
Depending on the type of voicemail you have It can be accomplished by calling in to the office and when the main greeting starts playing press **, the administrator mailbox number, the password and the pound key (default is 1020000). Once in the mailbox press either 9 or 99 at this point you can re record the main greeting.
2helpful
We have the Norstar Meridian (M7310) telephone system and would like to change after hours message. I cannot locate this information in our book. How do we change it?
To re-record greetings, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting either 2 or 4 (you might want to listen to the greeting first). press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
1helpful
Changing the greeting on the company's main phone
To re-record greetings, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
3helpful
I am trying to change the main greeting on our Norstar M7310. How do I do this?
first press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
How do you change passwords without knowing previous passwords in order to change voicemail greeting??
Actually, even as a technician, you will never know the origonal password.
But you can get in to reset the existing password back to 0 0 0 0.
There are a couple of steps; depending on your voicemail system, voicemail's are done differently, but try this first.
got to a M7310 set
-> dial FEATURE 9 8 3
-> password: 1 0 2 0 0 0 0
-> you should now see ADMIN and under that MBOX, AA, OTHR
press MBOX
-> press CHNG
-> dial the extension of the phones that you need changed
-> you should now see PASSWORD and under it RESET, press RESET (This resets the mailbox back to 4- zero's)
-> hit the * to back up and repeat fopr all the other extensions.
-> hit RLS after all is done and voila... you have now changed those passwords to those mailboxes.
Now when the new users dial F981 at their desks, and dial 0 0 0 0 the first prompt they get is pleasde change password.
2answers
M7310 manual
There should be a pull out card located in the base of the phone with instructions .
2answers
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
took this from a guide i have, might help you guys out
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
