Tablets & eReaders Logo
J
Judy Posted on Dec 09, 2014
How do I insert SIM card to Toshiba tablet model no AT7-B
1 Related Answer
Anonymous
  • 93 Answers
  • Posted on May 31, 2009
SOURCE: Unable to insert sim in lot provided for it dont know is this model is compatable with 3G communications as fujitsu specification said
Hello friend
(("You must remove the battery, then insert a SIM card into the 3G SIM slot toward the right of the battery compartment"))
Definitely it will work
Hope this info is help ful for you....
How to insert sim card in Toshiba tablet AT7-B
Some tablets do not incorporate mobile phones - check your apps for the manual or look here with your pc
Toshiba AT7 B8 Android 4 2 Jellybean User Guide for Excite AT7 Series
Sound is not working on Toshiba AT7-C tablet. Anyone knows how to fix it.
Notification option may over ride in some tablets.
Do cold restart of the device to hear startup sound.
I would also consider verifying the latest firmware.
http://support.toshiba.com/support/viewContentDetail?contentId=4006098
I purchased a tablet which uses wireless network only. I need a portable device which I can easily carry around. Or can it be unlocked?
If you have no wireless service available or hotspot to use. you can by a device such as Truconnect. It is about the size of a credit card and gives you private service to connect to your device. It is a use as you go deal. You load it up 20 bucks at a time and when your usage is about up it will automatically reload from your credit card . It connects to any wireless device just like you would connect to a router.
Where to insert a SIM Card in hp touchsmart tm2 1002tx model laptop?
1, Make sure that the device is turned off. Pull the card tray from the left edge of the device.
2, Take the tray out and insert the SIM card into the slot. Check if the card is inserted properly.
3, Press the tray until it snaps into place.
1helpful
Sim card in a panasonic cf-h2
To insert Sim Card in a Panasonic CF-H2, you need to open battery compartment 1 and remove battery, you will see where the Sim Card inserts, place the sim card gold side up in the depression. Slide sim card down the depression toward the sim slot, slide down till it clicks in place. Re-insert battery 1. Sim card inserted.
1helpful
Can you insert sim card into a samsung tablet 2 10.1
This model tablet supports MicroSDHC memory card.
Hello friend
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
