The check engine light appears as 1 long flash then followed by 5 short flashes. Car wont start once the check engine light comes on.
SOURCE: 91 Honda Acord) Flashing Green (S) an Check engine
you need a transmission computer located in floor on passenger side under carpet attached to the ecu computer you can get one on ebay for 120 dollars ALOT LESS THE parts store and it comes with a lifetime warranty
SOURCE: Code error P1361 Honda CIvic LX 2002
P1361 TDC Sensor Intermittent Interruption (I got this from Engine-Light-Help.com)
TDC should mean Top Dead Center.
It is the sensor that tells the computer the #1 cylinder piston is at the very top. And therefore, fires the spark plug.
Since the maintenance done above, I believe the the timing marks for the timing belt is not lined up properly. Being off by one tooth will cause this problem.
SOURCE: car brake lights won t turn off when car is shut down 1996 Honda Odyssey
It should be your brake light switch. There is a little plate welded to the arm of the pedal that has a hole with a rubber stopper. The rubber stopper is most likely missing, or damaged. You should be able to take a flashlight and see the plate and the switch. If the hole is plugged up, you will need the brake light switch, if not, replace the plug.
SOURCE: overheats once in a wile no codes on scanner.
I have a 2002 Honda Civic Ex, it has been over heating but only in stop and go traffic, never on the freeway, i have replaced, timing belt, water pump, cooling fan relay, cooling fan switch, flushed radiator. There is no white smoke coming from the tail pipe and the oil is clean, when the car gets hot i can smell the coolant pretty strong, car has never completly overheated gets about 3/4 of the way til red.
SOURCE: Car shut down while driving. doesn't start, but
most likely it is the ignition electronic module or maybe the reluctor coil at the ignition module.
