Tinkerbellpp is right about the 70032-00.001being out of stock. You can replace this with the 70030-00.001(chrome hinges) seat which will fit the Veneto Toilet. You can find this at your local dealer/showroom. Hope that helps!
First you want to reach underneath your toilet where the seat connects to it. You should see some sort of white nut. Just unscrew the nut from both sides. Once you're done with that pull off the old seat and place the new one on. Use the new nuts to tighten it down. For the most part you should be able to use your hand and not need any tools.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
Try this doc: https://www.plumbtile.com/mm5/pdfs/porch...
