I am not familiar with this particular machine, but I found references to the thread cutter. Did you try turning it off? Could the cotton thread be rotten, have you tried sewing with button thread?
Thread Trimming Function correlates with the scissors icon on the face of the machine. The G210 in unique in the fact that it has this function, which will automatically trim the thread for you, leaving virtually no mess! This one is a life saver as it relives you from having to spend time cutting and cleaning loose threads!
When experiencing a sewing machine jam and encountering an error message like "lower pressure foot" on the Juki HZL-F600 Quilt & Pro Special, it indicates there may be an issue with the machine's threading, bobbin, or pressure foot. Here are some steps you can take to troubleshoot and resolve the problem:
Rethread the Machine: Start by completely rethreading both the top thread and bobbin thread. Ensure that the threads are properly seated in the tension disks, thread guides, and the bobbin case. Follow the threading instructions in the machine's user manual to ensure correct threading.
Check the Bobbin: Remove the bobbin and inspect it for any tangles, knots, or thread buildup. Clean out any lint or debris in the bobbin area. Make sure the bobbin is wound correctly and placed in the bobbin case with the thread feeding in the correct direction.
Verify the Pressure Foot: Double-check that the pressure foot is properly attached and lowered. Ensure that it is securely in place and there are no obstructions preventing it from making proper contact with the fabric.
Adjust Thread Tension: Incorrect thread tension can also cause sewing issues. Experiment with adjusting the tension settings on the machine to find the optimal balance for your fabric and thread. Refer to the machine's user manual for guidance on adjusting thread tension.
Clean and Lubricate: Regularly clean and lubricate your sewing machine to ensure smooth operation. Follow the manufacturer's instructions for cleaning and lubrication, and pay special attention to the bobbin area and the needle area.
Seek Professional Assistance: If the issue persists after attempting the above steps, it is recommended to contact a qualified technician or the Juki customer support for further assistance. They can provide specialized guidance and troubleshooting specific to your Juki HZL-F600 Quilt & Pro Special machine.
Remember to always consult the machine's user manual for specific instructions and guidance. If you're uncertain or uncomfortable performing any troubleshooting steps, it's best to seek professional help to avoid potential damage to the machine.
If your Juki HZL-210 Excite's automatic thread cutter is cutting your thread when you're trying to straight stitch, there are a few things you can check:
Make sure you're using the correct presser foot: If the wrong presser foot is installed, it can activate the automatic thread cutter when you don't want it to. Ensure that you're using the appropriate presser foot for your straight stitch.
Check your thread tension: An incorrect thread tension can also cause the automatic thread cutter to activate at the wrong time. Make sure your thread tension is properly set for the type of fabric you're using and the type of stitch you want to make.
Clean the machine: Accumulated lint or debris can cause the automatic thread cutter to malfunction. Use a brush or compressed air to clean the machine, particularly around the thread cutter mechanism.
Reset the machine: Turn off the machine and unplug it for a few minutes, then plug it back in and turn it on again. This can sometimes reset the automatic thread cutter and resolve any issues.
If none of these solutions work, you may need to take your machine to a professional for servicing or repair.
The Juki HZL F300 Exceed Sewing Machine is a classroom model and will exceed ...High speed sewing up to 900 spm, stitches per minute; Power at low speed ...
Be sure that the stitch length is set to a higher number. The closer to zero it is set, the closer the stitches will be until zero when it will actually be sewing in one place.
Hi. Skipped stitches are usually caused by a mismatch in your thread and needle. Wrong thread type, wrong needle size, or even old thread can cause skipped stitches. If all else fails, change the needle. If that doesn't work, clean the machine. Sometimes just getting rid of all the lint and giving her a good oiling does a world of good.
if the machine regular needle threads front to back NOT side to side, you can use a double needle. simply pass both threads thru all the same slots (thread one at a time so they don't get twisted up) then just before the needles, leave one out of the thread guide just above the needle. you may have to loosen the top tension SLIGHTLY, like a half number. and do NOT use a zig zag stitch without first hand cranking it thru the cycle to be sure the needles clear, or you'll make a 5.00 mistake (the cost of the double needles!)
Loops on the bottom of the fabric direct the problem to the top thread. Rethread again and make sure the thread goes through the tension discs. Lift the foot, because this is what opens the discs. When sewing and the foot is down, the discs should be closed and thus giving the upper thread the tension it needs.
