White balance adjustment should be done. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: dark picture and green tint
Most TVs of that caliber have a life expectancy of about ten years.. In 2009 we'll be passing into the HD era and that Tv won't work without a little help from an HD converter. What you're describing sounds like some transistor problems on the crt board and possibly voltage regulation. Not too expensive for a reputable shop, but my best advice would be to get an estimate first. If you need help finding a reputable shop contact NESDA, (National Electronic Service Dealer's Assn.) they should be able to direct you to a member's shop in your area. Its like going to the AMA to find a doctor. If the cost is more than half the cost of buying new - get a new one... Good Luck Bill
SOURCE: green tint
Check 3.58 MHz color oscillator,, little metal can near large ic,
Also check color output transistors or any loose connections in the output stage
SOURCE: samsung txh1970 tv screen has green tint
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
SOURCE: my sony tv model #
Well it means something is wrong in the video out section.Unplug it ,and useing a ohm meter,check Q705,Q732,Q761 on the C board.Next check Q218,Q219,Q220, on A board,try turning the screen up a little. hope this helps you some.......
SOURCE: My TV picture has a developed a green tint to it
Hi , I think thats is your green cathode in the picture
tube , the only way to fix that is a picture tube regenerator machine you will find that in a repair shop
thats a delicate operation...
Testimonial: "Thanks,sounds like it might be an expensive job though."
