SOURCE: How do I hook up a Sony Handycam Video 8 CCD-TRV41 NTSC to view on television?
I still have my CCD-TRV41 and the manual intack. You will just need a audio/video cable (2-colored or 3-colored) to view your movies.
SOURCE: Sony handycam CCD-TRV318 NTSC Telephoto/wide
Tele-wide switch is fauly.(technical name is SWITCH BLOCK CONTROL).repalace by expert.
SOURCE: My Sony Handycam DCR-HC26 started giving me
the error c:31:23 error pertains to one of the reel (part that turns the tape) is malfunctioning. although you can play back videos, you would definitely have issue w/ recording, rewinding or fast forwarding the tape.what you can do is to turn the camcorder off.remove the battery and ac adapter for at least a minute.insert the battery or reconnect the adapter.you can also try pressing the reset button (located near the top of the speaker, on the panel where lcd screen goes to).make sure cam is on when you do that.if still your getting this problem, service would be needed for your cam.hope this helps :)
SOURCE: Sony Handycam Vision ccd-trv308
I have the DCR-HC32. I got the c:31:22 error with a message to reload the tape. I could load another tape and saw a post that if a tape is at the end and the tension is tight the camera has a sensor that won't load the tape so that it does not break it. I loosened the tape after a few tries and it loaded fine...no more errors.
