Whenever I turn on my computer my 19mvwk is saying no signal going to sleep . I double check make sure all the cables are plug in correctly and everything is alright. This sign is still coming up. The menu butons is not coming up. I am pressing and there is nothing doing the screen just shuts off by itself. Can you help?
Check the data cable is properly fixed. Can you hear the beep sound while booting. Check the ram inside the cpu.
Actually, I had the same problem. It's probably one of two things: 1) Set your Power Saving mode for the monitor to "NEVER" turn off automatically. 2) Sometimes if its an Energy Star model (probably is), it can't be plugged into an outlet with a lot of other stuff. 3) Try unplugging from current outlet to another one and also disconnect VGA cable. Then plug back VGA cable and replug into new outlet.
