User Ricoh aficio mp 2000 can't print asking for log in username and password? I never set any log in details, I have tried Admin,Supervisor with a blank password but not working, please assist
ChatGPT If you're being prompted for a login username and password on your Ricoh Aficio MP 2000 printer and you haven't set any login details before, there are a few things you can try:
Default Login Credentials: The default username and password for Ricoh printers are often set to "admin" for both the username and password. Try using "admin" as both the username and password to see if it works.
Factory Reset: If the default login credentials don't work, you can try performing a factory reset on your printer. This will reset all settings, including any login information that might have been set. However, keep in mind that a factory reset will also erase any other custom settings you have configured on the printer. To perform a factory reset, you can refer to the printer's user manual or contact Ricoh support for specific instructions.
What OS are you having?
On XP you can try this: Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows. Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista: Ctrl+Alt+Delete won't work, you have to use some windows password recovery software. I recommend Windows Password Reset
On XP you can try this: Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows. Now you can reset windows password from "Control Panel -> User Accounts".
On Win 7 or Vista: Ctrl+Alt+Delete won't work, you have to use some windows password recovery software. I recommend Windows Password Recovery Tool 3.0 .
On Win 7 or Vista:
By holding down the button in the back, you may have reset it to factory defaults for the password and username. Try using Admin for the user name and motorola for the password.
Hi to reset your password, please follow these steps --
1. Open the internet browser of your choice. 2. Enter 192.168.0.1 into the address bar. 3. In the username field select admin 4. By default the passsword is blank. If you changed it when you previously setup your router, enter the changed password. 5. To change the password used to login to your router, click on Tools in the menu bar at the top of the browser screen. 6. Under the Admin Password section, you can change the username and the password to login as an administrator. It is suggested that you change the username and password of your router. 7. Under the User Password section, you can change the username and password to login as a user. Logging in as a user allows you to see the settings, however, you are not able to change any of them.
If you would like additional information, please ask. Also, if you would like information on setting up your wireless, please post that question.
