Cars & Trucks Logo
A
A W HASTIE Posted on Dec 03, 2014
Remote control has very short range
New batteries in fob did not make any differance
mikeharrigan
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Dec 03, 2014
mikeharrigan
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
5287
Points
22
1. make sure battery is inserted correctly.
2. Do you have 2 remotes? Are they both exhibiting short range? Maybe bad remote if 1 is OK and the other is not.
3. Try this to extend range: hold remote under your chin and touching your chin while pressing the button. Your head acts as an antenna to extend the range.
  • mikeharrigan Dec 03, 2014
2answers
What are the locations of the Remote Control Door Lock Receivers RCDLR in a 2015 Malibu?
According to GM there are 3 components in the RCDLR or RKE remote keyless entry system. My key fobs with new batteries only work standing right next to the car. The range of the key fob dropped at that the same time my TPMS tire pressure monitoring system repair warning came on my dashboard. The problem is that there are 4 different components on the 2015 Malibu. I will provide the GM part numbers for these, if you please tell me where they are and also how to replace them: #13583559 Remote Control Door Lock Receiver #13502554 Antenna #13502551 Ignition Lock Key Transmitter Antenna #13502549 Low Frequency Console Antenna
2007 Honda Pilot: Key fob won't program
do you have remote start needs different programming then simple lock unlock and most locksmiths dont have that programming also is the for actually for your vehicle if have regular lock unlock below is how to program also when battery changed need to reprogram fob How to reprogram my Honda key fob insert the key into the ignition and turn the key to the "on" position. Press and hold either the "lock" or "unlock" button on the remote for one second. Release the button on the remote and turn the key in the ignition to the "off" position. Repeat this process two additional times.
Mustang alarm
Ford sold a Ford branded alarm through the parts department. These sometimes were a dealer installed option on new cars. Mine would randomly stop responding to the remote and I would have the same symptoms as you describe. I had it removed and the original equipment factory system still worked. Be warned, if you have the Ford "accessory" alarm, your key fobs (remotes) are different and the method to program them is different from what you will read online. You can tell if you have the system by looking at your key fob. The standard Mustang key fob is a 4 button (lock, unlock, panic, and trunk). The accessory alarm uses a 3 button remote and clicking unlock twice would pop the trunk. I really wish I had a picture of the remote because there are 3 button Ford key fobs for cars without a trunk release although I don't think you should have one on a Mustang. Long story short, if you have the accessory alarm, you can solve your problem by having it removed but you will need new 4 button key fobs to remotely lock/unlock your doors
08 chevy impala remote start fob range
any further than 20 feet and you have the car started and running is an open invitation for people to steal your car before you get to it
however you can spend time on the net looking for a site that sells more powerful remotes
Key fob
Walk out to the vehicle with a new battery in the key fob and press the lock AND unlock button at the same time while you stand close to the vehicle for 7 seconds. You will hear the doors go thru a lock and unlock cycle, your fob is now programmed. This will sync existing programmed controllers, security sync. to program new remotes:In the trunk, connected to the wireless remote controller (driver side on wheel well, need to remove 'mat') is an empty connector with 2 wires connected. short the two connector pins. The locks will all cycle. Press and hold lock/unlock buttons on remote until locks cycle on/off. repeat for other remotes. Remove short across connector pins. Test new remote(s).Warning:existing remotes are deprogrammed, only remotes programmed will work from now on.This worked on my 1998 Cavalier. Be sure battries in new remote(s) are good! Answer Locate the data link connector under the dash (under the steering column). Ground out pin #8 of the DLC (top right port) with a jumper wire to any piece of metal close by (I use the e brake hardware). The door locks will then lock & unlock to let you know you are in the programming mode. Simultaneously press & hold the lock & unlock button on one of the keyless entries until the locks cycle (this lets you know the transmitter has been programmed). Repeat this step for your second transmitter. You must reprogram the 2nd transmitter within 60 seconds of programming the 1st one or you have to start over.
Note
Read more: http://wiki.answers.com/Q/How_do_you_program_a_keyless_remote_for_a_1996_Chevy_Tahoe_LT#ixzz1wjwEcG4s
2helpful
2answers
Will not unlock with key fob, have replaced batteries
this usually happens when the battery has been disconnected from the vehicle, what happens is when the battery is disconnected the locking system fitted to the car has a pass-code that only the key-fob can access, as a result of the battery being removed the pass-code for the locking system on the car resets and does not recognise the fob being used. Your best chance to get this sorted is to take it into your local garage/dealer and get the fob linked back up to the cars locking system.
Key fob range not the same
try re-syncroniz see if that helpsing the remote.
3helpful
4answers
2005 Murano windows open by themselves
I had that happen too and found out that if you hold the unlock button down on your FOB for about 4-5 seconds then it will roll down the front windows. It's actually a feature, not a problem. You may have accidentally mashed something up against the FOB while it was in your pocket and you were within range of the car. That's what I did. Freaked me out the first time I walked out in the driveway and both front windows were down and I know I didn't leave them open.
5helpful
Remote key fob will not work-battery replaced
VW/AUDI/SEAT/SKODA
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
key.
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure
is the same, except you press the unlock button 2, 3 or 4 times for the
different remote.
For example : If programming 2 remotes press the unlock button twice with
a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote
control.
Remote Control Erasing (1997 ON)
Procedure
key.
3. Press the remote control unlock button 5 times in 1 second intervals.
A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory
erase.
5. Switch ignition OFF, all remotes are now erased.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
