I have taken out all the cartridges and cleaned the imput nozzles. I undid the screw and have cleaned the drain to the ink tank.(that was pretty messy) I soaked the sponge station with cleaner. The head is now sitting on a pad soaked in cleaner which I will leave overnight. But if that doesn't work what say you? The printer has performed wonderfully for years. Apart from a few heavy cleaning cycles and I did do a major head clean about 6 months ago it has had no problems.
SOURCE: epson 440 won't print
The ink dried up in the print head. A printer should be used at least every two weeks to keep from drying up the ink. You may have to replace the print head or have it serviced.
This is not much help. Bud
SOURCE: Can't perform a nozzle check - Sensor error load different paper
Hi tom_kolasa,
Here is the manual for your printer model. Epson Stylus Pro 9800 Printer Guide
http://files.support.epson.com/pdf/pro78_/pro78_gd.pdf
Hope that the manual contains everything you need from nozzle check to sensor errors.
SOURCE: I have replaced the Epson ink cartridges for
I Have this problem too with the pink ink, ive replaced it and now it will not detect that there is even an ink cartridge in the printer at all...
SOURCE: Can you Help me unclog
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
SOURCE: I have Epson Stylus Pro
MAINTENANCE REQ - 0040 - Pump counter has reached predetermined amount. This parts/units need replacement >> Box Assy., Flushing Pump Unit Cleaner, Head, A, ASP Cleaner, Head, B, ASP Porous Pad, Box, FL, Upper Porous Pad, Box, FL, Lower >>and then Counters reset. Epson Stylus Pro 4800 ->Contact Support
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
