Humax Hdr-Fox T2 500Gb Freeview Hd Digital Tv Recorder Logo
Posted on Dec 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My HUMAX free-view set top box seems to crash after it's been on for about thee hours,then reboots it's self in about four minutes. any ideas?
Steve
Level 3:
  • Master 3,290 Answers
  • Posted on Dec 02, 2014
Steve
Master
Level 3:
Answers
3290
Questions
Helped
1128171
Points
12184
This device has a fan that will turn on when the temperature of the internal hard drive reaches a certain level. The problem may be due to a faulty sensor, fan or both. here's a forum for this hardware that may be of help: http://hummy.tv/forum/forums/hdr-fox-t2-freeview-recorder.13/
Humax FVP-5000T Freeview Play Recorder. I cannot connect FVP-5000T to the internet. LAN is working plus all other internet devices.
Question edited for a lot more clarity.
Question moved to Humax category.
" I have tried all suggestions in your manual "
Not OUR manual, we are Fixya dot com, we are nothing to do with Humax, we are not who you think we are.
First, fully disconnect all devices from mains power for 15 minutes, router, television and the Humax Box. Plug in the router first, then the Humax and finally the television. It will take about 15 minutes for them all to come back online after the reset and all recognise each other. This is called a 'Power Cycle' and reloads all the software and connections. Then try again.
If that doesn't fix it, you can fully Factory Reset the Humax unit, or you can just go into Settings and put the router settings back in SSID and Password.
https://www.google.com/search?q=humax+fvp-5000t+reset
I need to know how to operate and set up a Humax TV set-top box recorder.
Question edited for clarity, 'humex' to 'Humax'.
Question moved from Cars and Trucks category.
They make a few models, but here an instruction manual. They can all be found using Google 'make MODEL manual'.
https://manuals.plus/m/0138caa99174c297359582f8a646f28b2f701887be87631db85aed03fd9d43a6
Mitsubibishi wd series 73"..Mitsubishi ws series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch ama
A couple of suggestions, if only on cable and using a box disconnect the set and box from power and after several minutes repower and see if a reboot helps.
The two models listed here both should also have a soft reset done with the original remote and the set on---Menu,1,2,3, enter.
1helpful
The humax keeps on messaging that the antane cable is short circuited. is this an internal problem or a problem with the aerial itsefl
The Humax PVR-150T will definitely have problems using an indoor set top aerial; this is true of almost all Freeview receivers. Freeview signals are typically hundreds of times weaker than terrestrial transmissions and if you've managed with a set top aerial so far it's been working more by luck than design. I find that most set top aerials are so badly made that they're often faulty when new, but as most tend to flogged cheaply at markets and car boot sales the supply chain has no incentive to improve the product.
There has recently been a national Freeview retune, to complete this correctly your box needs the kind of solid and reliable signal which you cannot get with a set top aerial. Some receivers had compatibility issues with the retune and in many cases manufacturers broadcast OAD's (Over Air Downloads) to update the firmware in the boxes to be compatible. OAD's almost never successfully install via set top aerials.
There is an official list of Freeview devices which are known to have problems with the retune; unfortunately it has not proven to be a comprehensive list. The Humax MG-TU1 is one of those which have had problems and from memory it's closely related to your Humax PVR. The official advice is that you contact Humax directly on 0870 247 8800, but they'll probably instruct you to test your box using the aerial system it's designed to use before they'll be interested in offering further assistance.
3helpful
I ws using my humax to watch a programme, when the picture froze.
It can sometimes happen if the signal level drops & the TV digital decoder cannot pick up the strength of the signal when the transmission is back to normal. Switching on & off again resets the processing again. This is a similar effect that can happen with cable or sky transmissions also, it acts the smae way as sometimes having to re-boot your PC if that should crash. It is not necessarily a fault with the TV.
5helpful
Humax Tivo Stuck on the welcome screen
I just had the same problem with mine and found another post that at least fixed mine.
I had a DVD in the unit as it was restarting. I took a flathead screwdriver and opened up the DVD slot by inserting at the top right corner and opening the door. On the inside, at the bottom right, is a button that ejects the DVD player (the eject button on the outside won't work while it's booting up). I ejected the DVD that was in it, unplugged the unit for 30 seconds, and then it rebooted just fine.
Hope it works out for you too...
8helpful
2answers
Humax digital recorder picture freeze every 10 minutes
Humax are having problems and are starting to send out software upgrades (night-time updates) - seems to be related to the new formats on the MUXs for the digital switch-over. Our 9150T hasn't been fixed yet but due any day (I hope)
3helpful
3answers
Thomson DVB Top Up Box
www.digitalspy.com/forums/showthread.php?p=31773855
IF you're lucky, this may help....?
This restes the bios but removes all recordings from the hard drive.
Good luck!!
Sagem pvr 6200T UK freeview box, display frozen.
I left the box and went for a walk!!!
About four hours after having freezed an error 09 message came up on the set top display and then everything returned to normal, after an on TV screen message that update had been successful.!?!
No difference in in any operation of the freeview box.
Note to self and other users
DO NOT PRESS OK WHEN ASKED TO UPDATE SET TOP BOX.
Updating the channel tuning does seem to work ok, though I have to vary between where channel 4 can be found - or learn welsh!
Top Humax Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
