Talkback not loud in my radio
You need to check the audio path from the chatback board to the audio circuit
usually the audio out the board will go to the center connection
on the volume control
sometimes people use a resistor to attenumate it to a level
or a T pad
and connect it to the left side {audio out to amp}
so a volume control works like this
left center right
ground audio into control audio to amp
so usually the center is used as the volume will track up as your sets volume is increased
so simply connect the audio out from the chatback
to the right audio to amp section
on the chatbacks ive made and installed in the past
had a small pot on the board
this allows the volume from it too be increased
so look for this first
if you cant find it you can make one up like this
100K log pot 3 pin
1 2 3
L M R {left middle right}
1= ground
2= audio from chatback
3= audio to the right right audio to amp on the cb's volume control
then no matter what level the actual audio from the set is set too
the chatback can be set to a standard level for all
hope this helps you
i used too build chatbacks for the rnid year back and fit them free
SOURCE: delta force magnum radio
Herman, one thing that should help is turn on the NB and also TONE .
SOURCE: Magnum Delta Force Radio:
usualy that is a sign that someone was trying to get more channels then it already has which is imposible to get any mor ok check this web site cbtricks.com go to the radio information section go to m look for the magnum radio section look for the deta force you should find all you need there. good luck with your projec and god bless you.
james morgan
morgans electronics
SOURCE: service manual
You may click this link for the service manual:
http://www.rigpix.com/cbfreeband/magnum_deltaforce_manual.pdf
Have a great day!
SOURCE: my magnum delta force blows the higest amp fuse!!! (shorting out)
yes it sounds as if the diode has gone short curcuit. this is at the back or near the in put socket. the diode is black with a silver end. replace with same size this should sort it out.
SOURCE: where can i download an owners manual for magnum cb radio
You can get the manual here on link below.
