All as above.checked pump,pipes, inlet outlet pipes,drain,E03 error code keeps coming up four minutes before the end of the cycle not taking fabric conditioner draining and pumping out the water to empty the machine.Please help machine 7 months old. still under manufactures warranty parts and labour, saying if not a machine fault, call out charge is payable
SOURCE: Washer will not finish final
When you stated you checked out the pump did you mean you removed the drain line from both sides of the pump as well as the drain line that attaches to the port hole off the tub and assured that not only there wasnt anything enlarged in the port hole of the tub which is connected to the drain line that leads to the drain pump itself? Also did you remove the pump from the unit and visually inspect that the impellar inside the pump was spining? You also stated that it will not drain last 4 inches without an error what is the error that the unit is showing? Lastly have you also inspected the lid switch to assure that it is properly positioned and not bent or broken? I await your reply to the questions that I asked also if you happen to have the model number it will benefit our chat whereas I can try locating your schematic to your unit. I await your reply
Thanks Rick
SOURCE: err02 shown during spin cycle on 1400 haier washing machine
WHEN I INVESTIGATED FURTHER I FOUND THE DRAIN TUBE FROM MACHINE WAS BLOCKED BY SOLID SOAP LUMP BUILT UP AT THE MACHINE END -AMAZING .
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
SOURCE: Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
