Tv wont turn on, red light is on romote light is flashing but still wont turn on and main bottons vol,programe change ect are not working please help thanks
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Code: 0206
4. Point your Sky remote control at your TV and press the vol + & vol - buttons. If this turns the volume up and down as you'd expect, then the tv should be set, press Select and the remote should work
press and hold the tv botton on you dish remote till all the lights light up release the tv botton it should stay flashing then hit the larger of the two red power bottons next you will need to hit the up arrow one at a time till the tv shuts off when the tv shuts off you then hit the # botton at the bottom you wiil see the tv botton flash your code will then be saved
This remote was also supplied by RCA for their VHS player, model # VR629HF.
The instructions to program it can be found in the user manual for the VHS player: http://www.retrevo.com/support/RCA-VR629HF-VCRs-manual/id/19241ag112/t/2/
1-Turn on the TV
2-Find the brand and code number(s) on the code list on the next page
3-Press and hold the TV button on the remote.
4-Enter the code from the code list.
5-Release TV, and then press CHAN up or down. If the TV responds to the remote commands,the remote is programmed.
6-If the TV does not respond, repeat these steps using the next code in the list.
u must press and hold the botton titled as code search until the red light is lit. Once you do so, you program in one of the 3-4 digit codes. I am actually dealing with the same delema. I have an Orion tv except i have no clue what the code for it is. If you could help me out with the code that would be great
wont turn on red light just flashes? On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
You don't need a code. Just follow the instruction as follows:
1. Tun on TV
2. Press and hold "code search" until light stays on, then release.
3. Press TV botton
4. Press on-off repeatedly until TV turns off
5. Press enter.
