Called out Charter Technician 5 times in a 5 week period . He cannot solve problem.
SOURCE: Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
SOURCE: Blue line problem with Sony Grand WEGA KDF-55WF655 Rear Projection TV.
We had the free repair from SONY for the blue dots and splotches. It works great now but you need to hurry and contact them as the offer expires I believe in December.
SOURCE: stanby light blinks 5 times
The sight in Jean's posting could help. Usually 5 blinks signify that the voltage is too low so you may actually have to turn the knobs up then back them off just until the retrace lines disappear. If one color dominates and you see retrace lines, you may want to turn that one down. But if the dominating color doesn't show retrace lines the other 2 might need to be increased slightly. If you Google Sony TV flashing led codes most likely you will come across an explanation of the codes. Hope this helps.
Please keep in mind many things can go wrong with TV
sets and you should really do a lot of research before attempting any
adjustment and or repair. There are high voltages present in some areas and they can
reside even when the set is unplugged.
