THE IMAGE SHOWN UPSIDE DOWN... NEED YOUR HELP PLEASE...
SOURCE: I mounted the projector on the ceiling and need to flip the image
Hey there jpotto, You will need to use the installation menu. Inside you will find an option called image flip. Options are HV, H, V. Check it out. It specifically is used for ceiling mounts. Good Luck!
SOURCE: Picture is upside down on screen
go into the menu using either your remote or the button on the projector itself. At the top are several options i.e. "picture" scr-adj. Click over to the right ONCE to "SCR-ADJ" this stands for source adjust. Then look for something called like PRJ mode (projection mode) This tells the projector which direction to display the image so that incase you want to hang it from the ceiling upside down you can. Click down to that menu option. You will then have to click over to the right in order to see your options. If you are using it hanging on a ceiling you want it to say "ceiling front" if it is merely sitting on a cart or a shelf just put it on "front".
Good luck.
SOURCE: image is upside down on projector
in amodel nec projector vt490 the status lamp is blinking or flashing and the machin not work
plz send me the problem and solusion.
SOURCE: I need to flip the image on the Infocus In2104
go into the menu, go to settings, image, and select ceiling (it's probably on "front" right now).
Testimonial: "Great information. Just what I needed."
SOURCE: my projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
it's a tv not a projector!!!!
thank you so much, :)
