How to unlock?
You can use a USB stick for region A, B or C. (1, 2 of 4)
On the USB stick there is one file named autoscript with the following : CLI(CLI_app.homemenu.set_bdreg 4). ,4 you can also use 1 or 2 this depends on the disired region.
Just copy this with textprogram and name the file 'autoscript'
T
1. Remove any discs from the drive of your player
2. Put the player into standby
3. Put the USB stick with the desired bluray region into the player
4. Turn on the player
5. Wait 5 seconds
6. Put the player into standby
7. Wait 10 seconds
8. Remove the USB stick
9. Unplug the mains cable
10. Unit should now be the region you have chosen for bluray
Before you do any firmware update, return to Region B as it may lock the region.hen do the following:
No links, and instructions seem to trail off ...
Works great! Does anyone have the file required for making the player DVD multi region?
For DVD: Create a text file called AutoScript, with the following content: CLI(CLI_app.homemenu.set_reg 0)
Put that file in a folder called AutoScript, copy that folder to a USB flash drive, then perform the same procedure as described above (steps 1 to 10).
Do we have to return to original region in case of DVD, too? Or can I leave it in region 0 during firmware update?
It seems the end of first answer is missing. '...Before you do any firmware update, return to Region B as it may lock the region.hen do the following:'
What sould I do if it lock region.hen?
it did not work! i created a .txt file on the wordpad for region 2 : CLI(CLI_app.homemenu.set_bdreg 2)
followed all the steps but it did not work.
Can you help me? What am i doing wrong?
Regards
Works great. Does anyone have the info required for DVD region unlocking?
