I just service my machine open all covers and clean it after when i fix all the machine i switch the power button but machine not on. pls tell me the solution.
SOURCE: Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
SOURCE: Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
SOURCE: Hi I have a Ricoh
The power supply unit within the printer also would have damaged while the surge took place . The SMPS - the power supply - is quite sensitive to the power surge and so could have damaged the driver or the front end . you need to take a look at the SMPS unit to confirm. remove the power supply and check for fuse, if the fuse blows again then you have a problem in hand. http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
check the link for tips:
