I need the repair kit for the not powering on. It blinks 3 times and that's it. Cp120, cp140, and cp114.
SOURCE: i need a convergence kit
what type of problem with convergence? no convergence at all? pitcure bowing? this in the setup menu do you have the convergence option? a convergence ki in a standad porojection has stk ic/s this model does not .you might have the fl231 fuse problem.. generally its board replacement. then the problem becomes alighnment.
SOURCE: RCA 52 in television
You will first have to see if cp150 is puffed up on top then go from there! Also you need to resolder all pinns on FBT poor connections on alot of these sets.HAPPY NEW YEAR!
SOURCE: Rca d52w19 push power flashes 3 times
The caps in these sets rarely bulge. Try checking the Horizontal Output Transistor (HOT). I suspect that it is shorted. The noise you are hearing is the power supply attempting to fire. With the defect further on, the power supply will turn itself off as a safety valve.
Keep us posted,
Dan
SOURCE: RCA R52WH74 turns off 3 times
Hello Kira-chan,
You are going to have to take those capacitors out of the Tv and check them on a capacitance tester. Some digital multi-meters have them, but I would suggest using the LC102 by Sencore That way you can check the ESR, and the dielectric absorption of the capacitor. It is my suspicion that these caps are bad, but should be checked before replacing them.
In addition check the BLUE and RED CRTs for cracks around the neck oy the tube, BE CAREFUL.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
SOURCE: I have a RCA D52W20 52" HDTV Ready TV which I
Unplug High voltage lead from HV splitter. This is a red wire going from HV transformer to similar (white plastic) device located up front, between picture tubes. Disconnect the one which is coming in, by strong energetic pull down with pliers. Leave those which go to picture tubs in. Make sure that disconnected wire is far from other components or metal parts (high voltage - SEVERAL INCHES SPARK CAN OCCUR) Turn the unit on - if different than 3 blinks - the splitter is your problem.
