I have problem with christie projector roadster x9 il cant access the keystone menu
If your's is the "s" model there is no keystone adjustment provided. Otherwise the keystone adjustment is found under MENU then 1, Size and Position and under MENU 2, Image Settings. Also, refer to this excerpt from the manual:
NOTE: This function is not available in "S" models.
Adjust the keystone control if images appears non-rectangular or keystoned in shape-that is, smaller at either the top or bottom edge. The effect of keystone adjustment is similar to
physically tilting the projector forward or backward in relation to the screen, and it affects all sources.
NOTES: 1) Keystone is enabled for a source only if Size is 1000 and Size x Vertical Stretch is 1,000,000.
2) Keystone adjustment is not available in "S"
models. 3) Avoid using Keystone with Blanking.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
SOURCE: Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
The automatic keystone adjustment may not be carried out correctly
because of the ambient temperature and the installation
conditions of the projector and the screen. In such cases, correct
the keystone manually.
• When the projector is projecting images where acceleration is
present, such as in a vehicle and aircraft, the automatic keystone
adjustment may not function correctly. In such a case, set AUTO
KEYSTONE in the INSTALLATION menu to OFF and correct the
keystone manually.
• You can correct the vertical keystones. However, their adjustment
ranges are limited in such correction.
When the keystone adjustment is carried out, the adjustment
value is indicated. Note that this value doesn't mean a projection
angle.
• The allowable range of the adjustment value in the keystone
adjustment varies depending on the installation conditions.
• When the keystone adjustment takes effect, the resolution
decreases. In addition, stripes may appear or straight lines may
bend in images with complicated patterns. They are not due to
product malfunctions.
• Noise may appear on the screen during the keystone adjustment
because of the type of the video signal being projected and the
setting values of the keystone adjustment. In such cases, set the
keystone adjustment values in the range where the image is displayed
without noise.
• When the keystone adjustment is carried out, the image may not
be displayed correctly because of the type of input signal.
