Clearing the codes is simple that is done by removing the fuse of the EFI from junction box 2 for 10 seconds. Make sure to remove the jumper wire and switch the key off before clearing the codes.
Here are some common Lexus vehicles 1990-1995 codes:
Code 12 and Code 13 Rpm signal circuit fault
Code 14 Igniter signal circuit fault
Code 16 ECT control signal fault
Code 21 and Code 28 Main oxygen sensor fault (for ES300; SC300 & GS300 models)
Code 22 Coolant temperature circuit fault
Code 24 Intake temperature sensor circuit fault
Code 25 and Code 26 Air fuel ratio fault (for ES300 & SC300 models)
Code 27 Sub-oxygen sensor circuit fault (for ES300 CA & GS300 models)
Code 31 Low airflow meter voltage (for ES300 and GS300 models)
Code 32 High airflow meter voltage (for ES300 model)
Code 35 Barometric pressure sensor circuit fault (for GS300 & SC300 models)
Code 41 and Code 47 Throttle position sensor circuit fault
Code 42 Vehicle speed sensor circuit fault
Code 43 Starter signal
Code 51 Switch condition signal fault (for ES300; GS300 & SC300 models)
Code 52 Code 52 and Code 55 Knock sensor circuit fault
Code 71 EGR system circuit fault (for ES300; GS300 & SC300 models)
Code 78 Fuel pump control circuit fault (for GS300 & SC300 models)
Trouble Code: P0301
Cylinder No. 1, 2, 3 or 4 Misfire Detected
Trouble Code Conditions: Engine is running; atmospheric pressure, fuel level, battery voltage, engine speed, engine load are above minimal predetermined specifications; the engine is not in fuel cutoff and intake air temperature and coolant temperature are within normal operating ranges; there are no DTCs relating to ECT, CMP, CKP, MAP or IAT Sensor, to Crank rationality, to Crank Sensor Learn invalid, or to System Voltage. If total misfires detected are greater than 7% during the first 1000 rpm, or are over 3% after the first 1000 rpm, or are 25% during any 200 rpm with suspect cylinder misfire counter more than 80% and no other cylinder misfire counters above 80%, this DTC will set. The MIL will flash after first trip occurrence and will be steady after second trip.
Possible Causes:
Fuel system problems existErratic CMP or CKP Sensor signalsIgnition system problems existEngine mechanical problems existPCM has failed
