I called the support line and they told me that because the light was not on by where it says on, that is very bad. The unit had the power on and it was running. Why would the tech say this?
Thank you for your inquiry, Lisa Cooper!
I understand that the power light on your Frigidaire dehumidifier is not showing you the power light is on. It sounds like you could have an issue with your control panel. If your dehumidifier is running it could be that the light has failed. If you have a current warranty I would reach out to your manufacturer to see if they have a resolution for such an issue. Hopefully this helps. -Matt
Hello dinesh878 - I found the manual on the Frigidaire website. Here is the manufacturer link and hope you find all the information that you need. I will recommend taking off the last letter of the model number so you can pull up the information.
http://b2b.frigidaire.com/support/manuals.asp?NewSearch=New+Search
