Lights in my kenmore refrigerator, freezer on bottom, burned out. I purchased two 60w bulbs and replaced them. I plugged in the refrigerator and the lights were on. Then a couple of minutes later, I opened the refer door and the lights were out. Then I waited for another half hour and the light were on again. I closed the door and opened it again in a few minutes and the light were off again. Any suggestions?
Hello Sharon;
My name is Peter. I am a retired field service refrigeration technician.
You can not put normal house hold appliance bulbs in appliances. There are special bulbs for refrigerators, clothes dryers and close washers.
The bulbs are usually available in the local market and marked; "Refrigerator" and Freezer".
You may have a bad door switch. But, I am more prone to go with the wrong service bulb.
Your Friend,
Peter, Baltimore, Maryland, USA
SOURCE: Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
SOURCE: SubZero 532 frig lights out
There are two door switches one for fan and the other for the lights. With the compressor running, there are two so yu need to make sure it is the refrigerator and not the freezer, open the door and press the right switch and listen for a fan. The left should be your light switch and the problem is generally in the switch, on rare occasions there is a failure of bi-metal safety switch part number 4200850. One very rare occasions you may have a wiring proble.If you go to www.subzero.com there is a showroom locator tab on the top right corner, click it and you will go to a locator page which will get you to your local parts didtributor.
SOURCE: Kenmore Elite bottom freezer refrigerator model 795.77573600
My Kenmore Elite (Model 795.7755 3600), less than two years old, had
the same problem. One morning I opened the doors to a hot fridge and
burning plastic. The light housing was sizzling hot - much of the unit
literally melting away. Another hour or two and it could have been
much worse.
Called the 1-800 number listed in the fridge. After about 45 minutes
of patient talking, I learned that Sears (or Kenmore) have issued what
they refer to as a "flash warranty) on the light fixture kit (Kit #
6871JB1423N) which in effect, for this part only, extends the factory
warranty from one year to three years. I may even be able to have a
factory tech install the parts. Hope it works out.
Bottom line: if you have this fridge, be very careful and monitor closely. An pursue the part warranty!
SOURCE: 3 beeps
We had the same problem. Our fridge was beeping and the lights would not come on. To stop the beeping and turn the lights back on we had to press the OVER TEMPERATURE RESET button. As soon as we did this, the lights came back on and beeping stopped. Hope this helps.
SOURCE: smelly water from door dispensor
I had the same problem. Drove me crazy and cost me about 5 filters at $50 a pop until I found the solultion. Water in the Sears/LG refrigerator that I have (french door trio) goes through the filter then into a container on the left front door of the refrigerator. That container stores the water so it can get cold and it also equalizes the flows in the system so that when you put your glass under the spigot the flow is steady and the water is cold. Problem is .... this tank can build up with algae/slime/foul tasting stuff. Since it is after the filter, no matter how many times you change the filter it will have no impact on the water in this container. That is why if you use the water spigot a lot, the water seems to get a little better (as the tank water gets diluted) but as soon as you don't use it for several hours or more, back comes the smelly water again. Solution for me was to remove the plastic panel on the inside of the left front door and clean the plastic bottle. It is pretty easy to remove with 2 screws and easy to pull off the hoses. I filled is with a little clorox and water and swished it around for several minutes then drained and rinsed it. Then I filled it again with a little clorox (like an ounce or two max) and put the container back into the fridge. Once in the fridge, I ran fridge water through the front water dispenser for about a gallon or so. This flushed out the chlorine in the plastic container as well as the lines between the container and the spigot. After about a half hour of work, my great tasting water in the fridge is back again. I've checked the taste on this water for several weeks now and no plastic/odor/bad tasting water any more. Hope this helps.
