Please tell me,how to download games for my lg ks360. i have tried several times but games which i first download into my pc and then copy-paste it to my lg handset does't work and plz tell me some good trusted downloading site.
Your phone probably has a bad internet connection.It is always good to be connected to a Wi-Fi source if there is one.. If not, you may need to go to an area with better service.
Reply if you have other questions.
Good luck,
Cooper.
(Please leave good reviews, I am doing this for summer work!)
You can get games by going to different mobile sites that allow you to download mobile games for free. You can try out the links below and see if they help you get what you need. 1.http://gallery.mobile9.com/c/lg-ks360-softwares_1901/1/ 2.mobango.com 3.getjar.com Hope this was useful to you? Please comment for more information and thank you for using fixya
Ok, if your PC is able to read the card your phone is rejecting, copy all its contents to your PC. Then, format the card using this program, copy the files back to it, and reinsert it on your phone.
Hope it works for you.
Regards,
Carlos
Delete them all and download again from a different site to External memory stick or via Pc. You could also try using different folders - sometimes my folders dont work for some things but do for others. then i change them around once they are on the phone
I think that the KS360 doesn't have the right codecs to play MP4, my videos are formatted as WMA, and they work fine. And for the games, you have to go to the main menu, and you have to go to the section "Games and Apps", from there, you have to go to "Network Profile", and you have to create a new one, and you will be able to download games.
I was beginning to think there was no one else from the UK on here :) lol
Here goes, beware its complicated and you can mess up your phone :)
This works without uploading anything to the phone. Just follow the instructions carefully. You will need 4 bits of software to perform the unlock - get them all now Download the USB flash loader driver here go the the download USB driver section and find the KS360 United Kingdom Driver. http://uk.lgmobile.com/web/web.product.manualSoftwareRF.laf Download the Orange Firmware here (it doesn't matter if you are onOrange or not - it does not get uploaded to the phone, it is justrequired to make the following software work). http://ks360.assembla.com/wiki/show/ks360/Liens_LG Download the Extract program here http://www.pb4kn.co.uk/extract.zip Download the LG Utils zip file at the top of the list here http://www.assembla.com/spaces/ks360/documents?c=documents.updated_at&d=down&page=1
You will also need the USB cable which came with the phone - but don't plug it in yet.
Youshould also make sure you have saved all your phone numbers just incase - I have carried this out several times without any problems, butyou can never be too careful.
Follow these instructions very carefully: 1. Install the USB flash loader software (contained in a folder in the first download above) 2. Switch off the phone and leave it off. Do not switch it on until you complete step 14. 3. Plug the USB cable in the computer and phone - wait for it to install all the drivers loaded at step 1 4. Unplug the phone and leave it switched off 5. Create a new folder on your computer (I suggest c:ks360) 6. Double click the Orange Firmware cab file downloaded earlier 7.Select all the files in the cab file. Copy and paste them in the folderc:ks360 - you will need to click save file a number of times. 8. Unzip and run the extract program downloaded earlier o Type c:ks360Inf_WebDnld.dll and press enter o Type c:ks360V10G.wdb and press enter o Type V10G_04 and press enter o Press enter (and wait a few moments) 9. In the folder c:ks360, some new files will have appeared. Rename KS360AT-XX-V10x-ORG-XXX-SEP-23-2008_slb.flb to KS360.flb 10. Extract all the files from the LG Utils zip file downloaded earlier 11. Run KS360-Utils-EN.exe and choose option N o type .USB1 and press enter o Type c:ks360ks360.flb and press enter o Type STATIC_EEP (get ready to connect the phone) o Press enter then within 1-2 seconds, connect the phone (still switched off) (timing is critical!) 12. If successful, a new file called STATIC_EEP will appear in the folder where KS360-Utils-EN.exe was unzipped 13. Copy STATIC_EEP to the c:ks360 folder 14. Run KS360-Utils-EN.exe again and select option O and press enter o Type c:ks360STATIC_EEP and press enter o The unlock code appears - write it down and close the program. o (If you get an error message, repeat steps 11-14 - the timing at step 11 is critical to this working) Now you can unplug the phone and switch it back on
1. Enter the following number (as if you were dialing a phone number): 2945#*71001# 2.When prompted for a password, enter the number you wrote down in step14, press OK, restart the phone......SUCCESS!! Your phone is nowunlocked
