How do I reset please
Is this for xbox 360 or xbox one?
regardless here is the links your looking for...
support.xbox.com/.../contact-us you cannot reset the password from the web or on the xbox you ahve to contact customer support. when you click this link it will ask you to click on the appropriate xbox you have whether its xbox 360 or xbox one.
SOURCE: ps2 parental control
You may want to try "5432" when you have to enter the code (not to delete the code, but where it asks you to enter it when you insert a movie). My friend had the same problem, and that's the code we used (after an hour of entering random numbers) to get past the parental control lock.
SOURCE: I WANT TO REMOVE PARENTAL CONTROL
this is not a soultion but does it have forgot your password click on it and it might solve your promblem
SOURCE: Parental Control password reset for PS2
At the screen prompting you to input the password, enter the digits 7444. The previous password will be deleted, allowing you to create a new one or you can leave it blank.
SOURCE: I need to reset my playstation2 parental control
hi just put 7444 it will ask you to input a new one. just leave blank. rember give me a good rating if it works :)
SOURCE: Forgot Xbox 360 parental controlls password
they can either use the password reset answer or contact xbox live via the phone.http://support.xbox.com/support/en/us/nxe/contactus.aspx
good luck
Hi Jessica
There are two methods to reset the Parental Control on a PlayStation 2, the Quick Method and the Easy Method.
The Quick Method to Reset Parental Control
If you do not know the Parental Control password on your Ps2, try the known defaults of 1111 and 7444.
The Easy Method to Reset Parental Control
Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you forget your password, press the following buttons on the remote,
one by one: MUTE, DISPLAY, CLEAR, and RESET (you must be in the
password entry screen). Parental controls will then unlock and you can
re-enter a password via Lock Parental Controls.
If you need the manual please let me know.
