I have a Casio DBCW150-1 Databank watch that is getting close to needing a battery change. I don't know why Casio stopped making these, they are great watches. My problem is that I have tried changing batteries in these (regular databank watches) before and they never worked afterwards. Something about grounding the batteries to reboot the watch. I was wondering if this watch was similar to those, and if so, can you give me any pointers on the proper way to accomplish this battery change. Normally I would throw it away and buy a new one, but I can't find one anywhere, since they have been out of production for quite a few years. Any help will be greatly appreciated.
Thank-you
Steve
DONT THROW IT AWAY THAT IS A COLLECTORS ITEM... You can get it taken care of at www.casiowatchrepair.com or call them toll free 877.659.0761 and have them take care of it, the watch will be as good as new.
Just did this to my Casio 2296. (DBCW150) Take a twist-tie off a loaf of bread, or some such thing. Strip both ends of the wire clean. Take the back off the watch with a 00 Phillips screwdriver. Do NOT turn the watch body over, or one of the three tiny springs might fall out. (They touch contact areas on the back plate.) Just leave it flat on your work surface. Find the hole in the plastic marked "A". You'll see a teeny contact on a circuit board at the bottom of the hole. The entire oddly-shaped metal plate on the back of the plastic piece inside is the "-", or ground, contact. (Somewhere on that plate is a circle with the "-" mark inside.) With your clean-ended wire, touch one end to the "A" contact in the plastic hole and the other end to the "-" metal plate. Hold that for 2 seconds. It is now rebooted and ready to use. Put the back plate back on.
