SOURCE: 65" Mitsubishi projection tv, my colors are not matching up.
If red or blue will not adjust in some direction--you have a Convergence circuit problem---
This model (WS-65809) uses two of the STK-392-570 Convergence IC's---
Green
for a good reason is not adjustable in the customer mode---it is only
adjusted for the Geometry or straightness of the picture and then red
and blue are adjusted to it.
If you are able to do this repair
yourself you can save the set and a lot of money---most shops charge
300-400 for this type of repair in this set.
You can buy both
chips for about 14 dollars on Ebay- and I have step by step---start to
finish instructions for this repair in this set--they tell also
everything you will need to do and what you need.
If you want the instructions let me know---I am not allowed to post MY email here.....but you.....
Not everyone can do this repair---Let me know if you have any questions or need advice----
If
you get someone else to do the repair make sure BOTH chips get replaced
or the set will have the same problem again in a few months.
Regards, SD TECH
SOURCE: Image problem with WS-65809 65" Mitsubishi Projection TV
WS-65809?, if convergence is skewed and comes and goes, uses two of the STK-392-570 CONVERGENCE IC chips.
I
have seen a lot of the Mitsubishi sets that use these two chips where
the convergence jumps in and out. You need to replace both chips and
adjust the set.
You can buy a pair of the chips on EBAY for less than 13 dollars plus shipping.
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THE SETS THAT USE THESE TWO CHIPS.
If
you or someone you know can do the repair you can save the set and a
lot of money--most shops are going to get at least 300 for this kind of
repair--I know as I have done hundreds of them here.
The
instructions tell you everything you will need and how to do the
repair. I have helped many people here do this based on my instructions.
If you want the instructions let me know and I will either post them here or send them to you.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
SOURCE: Mitsubishi WS 65809 65" Rear Projection TV. Turns
Hello There,
Its seems that the circuit board has problems.
You'll have to get it replaced ASAP before the board is ruined completely.
Thank you for using FixYa! I hope that I helped you & that this post is helpful to you at most! Don't forget to rate! :)
The same thing also happened to me 2-3 weeks ago. the techs came in and had to replace the board since 1 circuit was damaged.
It will cost around $100
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial}
Hi Christian Rembert, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
