REPLACEMENT SEAL FOR THE BOTTOM OVEN TKC 8525/2 720 EFA MODEL No 058587098 SRIAL No 80317905
SOURCE: i have a tecnik tkc 1255/ss range oven serial
You dont happen to have the LPG jets that were supplied with the cooker do you? I'm having trouble getting hold of any?
Thanks,
SOURCE: tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
SOURCE: My TKC 8525 double oven
One other tech at this site stated that the oven control goes through the main clock...so if the main clock is set to "auto", the oven will come on at certain times. Make sure the main clock's set to "manual", and see if that helps. Disconnect the power and turn it back on, then reset the clock, and that shoud do it.
Other than that, the clock/timing circuit or main controller circuit could be totally shorted, but that seems too obscure.
Hopefully this will helps.
SOURCE: I have a Tecnik TKC
If the red light does not come on, then this suggests that the oven thermostat or control switch is fault.
Even if the element was faulty, the red light shuld still come on.
SOURCE: I have just moved into a new house which has a
I have asimilar problem. HAve you solved it yet ?
