I formatted my n70 memory card on the pc..when i checked my memory card on the phone's setting it says "memory card corrupted". i tried to format it again on my phone but still it ays it is corrupted. how do i fix this by not buying another memory card?
Hey the problem might bewith tht type of file system u r formating it to try formating it to different types of file systems...
Sorry, but I'm not sure that there IS a way to fix that without buying a new card. If the card is corrupted, there really isn't much you can do about it.
~Aeoryth
Use mcfix softwere found in keywap.Net
Corrupted
SOURCE: i formatted my n70 memory card on the pc..when i
i think it might not your memory card is the problem its your phone, or try to replace a memory card or borrow from someone and try it ones more.
Try some of the following:
1. Try inserting another MMC card in your phone to check whether your card slot is working.
If it is readable, then it's memory card problem. In that case, you should format your MMC card by using a memory card reader and format it on your computer.
If it doesn't work for you, please write again.
Thank you
