Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
Posted on Nov 11, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Timer light blinking
Age of WD62725 - 3 yrs
Lamp life: less than 4k hours
Supply Source: connected to Monster Power HTS 1000 Power Center
Problem: Timer Light Blinking system shut down
Reset worked first two times, but after ~ 1hr of use in between shutdowns the picture would begin to 'flutter' and the system would shut down after a minute or two of this. After the second time I kept the system off.
Manual says obtain a line conditioner or power surge protector, but as I mentioned above I have one. I tried separate house circuits, but same results.
Could it be the power supply of the TV and, if so, how much is this and is it worth it?
  • 1 more comment
  • FixMe2 Dec 09, 2007
    I have a blinking timer light. This problem occurred about 2 months ago and was resolved with the reset button. Unfortunately, the problem has reoccurred and the reset buttom has no effect. No sound, no picture.
  • Anonymous Jan 04, 2008
    I have exactly the same problem. I lost power for a couple of days and now that it is on my tv timer button just blinks. I cant seem to reset it at all. It won't power up.
  • rick gajin May 04, 2008
    Hi I have the same Timer light blinking problem I change the 4 caps on power supply board but problem still dear
Anonymous
Level 2:
  • Expert 80 Answers
  • Posted on May 22, 2008
Anonymous
Expert
Level 2:
Answers
80
Questions
0
Helped
57333
Points
120
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
559
Points
Wh I turned on my Mitsubishi WD-62725 the green timer light keeps blinking but no picture. The reset button dose not solve the problem. Bulb is only a few months old. Do you have instructions on how to check/replace power supply and capacitors?
Anonymous
Level 2:
Champion:
  • Expert 208 Answers
  • Posted on Feb 29, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
208
Questions
0
Helped
237870
Points
496
Most likely bad caps on power supply bd. We have had the most problems with the 2 3300 uf caps. but there are 4 1000uf caps that can also be a problem. The main concern is to get to this power supply requires a great deal of disassembly and may require a qualified Mitsu tech.
Monster Power HTS 5100 MKII flashing LED and display is flashing 0800
The flashing LED and "0800" on the display of your Monster Power HTS 5100 MKII might be indicating an abnormal voltage issue. The "Abnormal Voltage" indicator on this model lights up if the incoming voltage is below approximately 90V AC or above approximately 125V AC 1.
Similar indicators are noted on various forums where users have experienced abnormal voltage readings with red flashing lights indicating the abnormal voltage, although the voltage readings may vary slightly
2 3 4 .
Adjusting the dimmer seems to temporarily resolve the issue, as per your observation. The dimmer knob on the Monster Power HTS 5100 MKII adjusts the brightness of the digital input voltage and current usage meter, which might be momentarily affecting the readings or the display 1 .
In a somewhat related case with a different Monster Power model (HTS 2000), a user faced a similar flashing "080" and "000" issue. The solution involved disassembling the unit and replacing one or more poor quality capacitors that had likely failed 5.
The problem might be related to a hardware malfunction such as poor quality capacitors or something else affecting the voltage and amperage readings. In such cases, a professional inspection and repair might be necessary to identify and fix the root cause of the issue.
It's advisable to consult with a qualified computer technician like Geeks On Command, or contact Monster Power support for professional assistance regarding this issue.
1helpful
How do you reset the monster ower hts 1000 mkii?
Press the PowerCenter Thermal Circuit Breaker button in to reset. Please allow
10 minutes before attempting to reset.
If you reset too soon, the breaker will
prematurely sense power overload and
not allow unit to operate.
• If the Circuit Breaker continues to trip,
try moving one or more components
to another PowerCenter. You may be drawing
too much current through one PowerCenter
I am trying to charge my PSX. The Charge light just blinks and it is not charging. What is wrong?
Those have a 1 year warranty so depending on its age it is probably due for replacement.
They should be charge once a month or after each use.
Montster Power hts 350 power conditioner
it depends on where it is and where to find a bulb may have to contact the company itself
Monster hts 1000
If half the plugs are not providing power, the most likely explanation is that the ON/OFF switch is in the OFF position.
In this position, the Unswitched outlets will stil be powered, but the Switched outlets will be OFF.
1helpful
4answers
Onida hts-1000 remote model no
I want remote control onida HTC 1000.pls. My contact no.9978945063
1helpful
My monster power HTS 1000 has a loud buzzing sound, should it be replaced ?
take it back to the sort where u bought it from and they should replace it with a new 1
Green timer light blinks fast after power loss
If this is a Mitsubishi you have a problem on the dm board, if it is a wd series there are some capacitors that buldge on the top that can cause this, if it is a ws series then you usually have to have the dm board replaced.
Monster power hts 2000 mkII
Usually the clicking sound is when the unit switches from powering the devices attached and charging the batteries, do the devices attached to the ups still function?
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
