I have a top freezer LG refrigerator - lrtn23311tt that stops working after it gets to temperature. I have defrosted and cleaned the coils. All but the 1st light on the temperature control panel is lit.
I can't find anything with that model number.
Download Manuals
SOURCE: GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
SOURCE: Temperature Control not working on LG fridge
It is an error code. The thermal fuse in the freezer section has gone. It has to be replaced. To get by in the short term, uplug the unit for 15 minutes, then plug it back in. It will run until it hits the defrost again (approx 5 hours) Part location is 401A and part number is 6615JB2005C. It is easy to change once you get the back cover off. Plug in part.
Sgt 48
SOURCE: GE refrigerator TBX25zpk coils Freezing
It's almost always the defrost heater. If you have volts to the defrost thermostat the defrost control is working. Set your meter to check ohms and remove the wiring from the heater. If anything changes when you touch the meter leads to the heater terminals then the heater is probably good, but my guess is nothing will change, which means you've got a bad heater.
fan won't start by itself.
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
-0--0
