Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
B
Betty Swickhamer Posted on Nov 08, 2014
<!-- from fixya rte -->Where do I find my guest password - Cisco Linksys E1000 WirelessN Broadband Router Network Routers
jon d
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Nov 08, 2014
jon d
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
18523
Points
73
All depends on the make but genraly if you login to your router usually its admin then password admin again or changeme or what ever password you have been given then go to wifi settings and its usually at the botum of that page have fun
1helpful
2answers
tip
How to Bypass Windows 7 Password?
Question: How do I bypass a Windows 7 account password if the only account I can access is guest? Can I <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 password</a> with the guest account? I forgot my Windows 7 administrator password, how can I regain access to my computer without the password? I have no Windows password reset disk.<br /> <br /> Recently I met many similar questions. Are you troubled with the same problem, also forgot Windows 7 password? Well, before answering the question, you should understand what a guest account is?<br /> <br /> <span style="font-weight: bold;">What is a guest account in your Windows 7?</span><br /> <br /> The guest account in your Windows 7 only allows people to use your computer without having access to your personal files. With the guest account, you can't install any software or hardware, change settings, or create a password. Because the guest account allows a user to log on to a network, browse the Internet, and shut down the computer, you should disable the guest account when it isn't being used.<br /> <br /> Solution: After learning the definition of a guest account, you can understand it is not possible for you to <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 user password </a>through the guest account. But you can bypass your Windows 7 password, with Windows Password Recovery Tool 3.0, a safe and efficient tool for you to bypass Windows 7 password. It allows you to bypass your lost Windows 7 password in less than 5 minutes.<br /> <br /> <span style="font-weight: bold;">What is Windows Password Recovery Tool 3.0?</span><br /> <br /> Windows Password Recovery Tool 3.0 is professional Windows password reset software with 3 editions: Windows Password Recovery Tool 3.0 Standard, Windows Password Recovery Tool 3.0 Professional and Windows Password Recovery Tool 3.0 Enterprise.<br /> <br /> It is designed to bypass Windows domain password, Windows administrator password and user password. With this Windows password recovery tool, you can instantly regain access to your locked computer by burning a bootable CD/DVD or USB flash drive on your own. No need to reinstall computer or pay to PC experts when you forgot administrator password or domain password on Windows 7/Vista/XP/NT and Windows Server 2008(R2)/2003(R2)/2000.<br /> <br style="font-weight: bold;" /> <span style="font-weight: bold;">How to <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 password</a> easily?</span><br /> <br /> Step 1: Download and install Windows Password Recovery Tool 3.0 Professional.<br /> <br /> Step 2: Burn bootable CD/DVD or USB flash drive.<br /> <br /> Step 3: Set your locked computer to boot from CD ROM or USB.<br /> <br /> Step 4: Choose the installation path of Windows, and enter the ID of the path.<br /> <br /> Step 5: All Windows account user names will be displayed for you. Enter the ID of a specified User Name to remove its account password.<br /> <br /> Step 6: Enter y to confirm and continue your operation.<br /> <br /> Step 7: Enter y to remove another Windows account password or enter n to finish your operation when the selected windows account password is removed.<br /> <br /> Step 8: Take the burned USB flash drive out of computer and press any key to restart your computer when you enter n to finish your operation.<br /> <br /> The Windows 7 administrator password has been successfully reset and now you can access your computer without password. Please note this method to bypass Windows 7 password takes effect only when you log on computer after <a href="http://www.windows7password.net/"><span style="font-weight: bold;">Windows 7 password reset</span></a>.
on Nov 22, 2010 • Computers & Internet
tip
Question: How do I bypass a Windows 7 account password if the only account I can access is guest? Can I bypass Windows 7 password with the guest account? I forgot my Windows 7 administrator password, how can I regain access to my computer without the password? I have no Windows password reset disk.
Solution: After learning the definition of a guest account, you can understand it is not possible for you to bypass Windows 7 password through the guest account. But you can bypass your Windows 7 password, with Windows Password Breaker, a safe and efficient tool for you to bypass Windows 7 password. It allows you to bypass your lost Windows 7 password in less than 5 minutes.
What is Windows Password Breaker?
Windows Password Breaker is professional Windows password reset software with 3 editions: Windows Password Breaker Standard, Windows Password Breaker Professional and Windows Password Breaker Enterprise.
How to bypass Windows 7 password easily?
Step 1: Download and install Windows Password Breaker Professional.
The Windows 7 administrator password has been successfully reset and now you can access your computer without password. Please note this method to bypass Windows 7 password takes effect only when you log on computer after Windows 7 password reset.
on Nov 18, 2010 • Computers & Internet
2answers
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
How do Setup a password for my router already have one password need to set a password for guest
You need to use your browser to log in to your router. Locate the guest account in the menu and set a new password. If you'd like, many routers allow you to disable guest accounts entirely. If you need specific step-by-step instructions, I need to know what brand and model router you are using, what OS your computer has, and what browser you use for accessing the internet.
2helpful
Password for guest Cisco connect
For me I am using my laptop and my laptop call Toshiba what can I do make my internet on for good cause it tell me that I have to enter password for Cisco quest access
How do i change my password when im on as a guest
Which operating system are you on ?
Windows allows you to create a guest account that is limited in terms of its ability to change settings and download content and software. At times, you may want to reset this account's password, which is easily accomplished.
Log into the system as the administrator. Click the "Start" button and then "Control Panel." Choose "Administrative Tools" and choose "Computer Management." Click "Local Users and Groups" in the left column and then "Users." Right-click "Guest" in the main menu and choose "Properties." Enter the old and new passwords. Confirm the password. Click "Next" and "Finish."
Create a secure Guest Account in Windows 7 http://content.techrepublic.com.com/2346-12843_11-459655-4.html
1helpful
3answers
How can i reset my admin password from guest?
You can't reset the admin password form guest, but you can reset the guest password from the admin.
Do as following methods to reset your admin password.
Step1: Download Windows Password Reset Deluxe ( http://www.windowspasswordreset.net ) and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows 7 password on the operation interface and logon PC without password.
Related: http://www.windowspasswordreset.net/article/article.html
Want to put lock on guest
Linksys E series routers can broadcast 2 wireless networks. First one is the main wireless network which is secured wireless network.
The second network is a guest network which will always show you unsecured.
It will never show you secured and you can not make it secured.
However it has a web based security.
Anyone can connect to the guest network but will not be able to access Internet without Guest access password.
In other words there is a security.
You can disable guest access also.
See more about Cisco Guest network access password
1helpful
2answers
I need to know how to get the guess acount password for an acer aspire 5050
Reset password > Possible.
'Get password' > Not possible. Native OS design does not provide this function
Quick fix: If you can login as 'guest', do so. Once done, press CTRL +
ALT + DEL and then click 'change password'. Follow subsequent steps. This becomes the account password.
Assuming you cannot login in with 'guest', do so with an account that has administrative rights.
Before proceeding, remember a key principle. To keep protected information secure, after a password is reset on a local user account, Certain information is no longer accessible, including the following:
  • E-mail that is encrypted with the user's public key
  • Internet passwords that are saved on the computer
  • Files that the user has encrypted
Now that we got that out of the way, Right mouse click 'computer'
Select 'manage' | 'Local Users and Groups' | (all in tree on the left)
Select Users folder
Shift focus to the detail pane on right. You should see 'guest'
If the guest account has an icon [arrow pointing down], it is disabled. This is a default setting in most systems. Not a good idea to activate it coz it leaves a door open for hackers.
Right click 'guest' and select 'properties'. On the general tab, you should see a check box next to the line [Account is disabled]
Enable/Disable per your pleasure. Click 'ok' back to main screen.
Right click 'guest' again. This time, select the first menu item - 'Set Password'.
Populate with your desired password. Remember it lest you are doomed to go through the whole process again.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
