Question about RCA P52926 52" Rear Projection Television
RCA P52927 volumn control
RCA P52927. The volume adjusts itself down and will not go up. Sometimes the volume control will start working then al of a sudden the volume turns itself down again. The power button also works off and on.
  • Joe Wade Nov 29, 2008
    same problem
  • 927 Answers
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
Posted on Jun 01, 2008
6ya staff
SOURCE:
The color adjustment won't work. I click on it and go down on other adjustments but none will open to adjust the colors.
you can buy a universal remote for 1 dollar.. option 1 however if you are using componelt input as in RGB then you have no control over your colors
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Oct 07, 2014 | RCA P52927 52" Rear Projection TV
I've got a rcs STAV 3880 surround receiver wit ful volumn al the time
Sounds like a shorted audio IC or bad connection in the limiter circuit.
Mar 01, 2014 | RCA Optimus/Stav-3880 Rcvr Parts - Board -...
RCA Stav-3880 turn stereo on goes to full volumn
Take the batteries out of the remote control, then apply a piece of black tape over the IR sensor, Unplug the power, wait a few minutes, now power the unit back up, does the unit still have the same volume high symptom? If so, remove the tape and see if the unit responds to any other commands(other than volume) from the front panel. If it responds to the panel controls, the processor is most likely good. very seldom is the IR transistor bad, if it is no input command will work.
Feb 15, 2014 | RCA Optimus/Stav-3880 Rcvr Parts - Board -...
How to turn the volumn control on on the acer laptop. tHE VOLUMN control is on off and it won't let me turn it on. My acer laptop uses windows7 '
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Mar 31, 2011 | Acer Computers & Internet
Where are the volumne buttons on the dell inspiron 2650 laptop. which keys on keypad work for volumne
You can adjust the volume by holding down the 'Fn' key (bottom row, second from the left) and pressing Page Up and Down keys (on the far right) to turn the volume up and down respectively.
Dec 31, 2009 | Dell Inspiron 2650 Notebook
Need to adjust incoming calls volumne up
Hi
most phones only allow you to increase/decrease volume of earpiece whilst your in a call. Whilst making a call the buttons on side of phone (up/down) should allow you to adjust volume. Sometimes these buttons also allow adjustment of ringer volume when not in a call. Hope that helps?
Apr 23, 2009 | Cell Phones
How can i turn the volumn up & down using the keyboard
If your volume controls are not working you may need to reinstall or update your drivers. These drivers are available via the dell website just use this link.
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Dec 07, 2008 | Dell Inspiron B130 Notebook
Radio volumn goes down when braking
if there is a menu button or something like it look for avc auto volume control set to 0
Nov 13, 2008 | 2006 Ford Focus
RCA P52927 sound is static
Need adjust coil sound ( little metal beside Big IC or between tuner and IC). Turn a little right and left ( be sure leave same position) don't play with this coil too much, will mess up video signal , some times tuner need be re solder. I hope this will help you Thank you!!!
Jun 30, 2008 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
183 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
