I was checking my email and it suddenly just locked up. I've looked up multiple ways to unlock it but none have been helpful. I have tried clicking the icon in the bottom right, and I have tried pressing Fn+F7 and neither one had any success. I get no other options from searches. Please help!
SOURCE: keyboard and touch pad locked
reboot- if that does not work the keyboard/touchpad may be disconnected or bad. ram is under an access panel on the bottom in the middle- you need a small screwdriver to add ram (ddr)
SOURCE: Mouse pad buttons not working
If the left mouse button is not working, then it is most likely the microswitch in the button has failed. To fix, you will need to replace the palmrest assembly
SOURCE: intel PRO/Wireless is turned off and I need help turning it on.
just go to Network Connection >>right click Wireless Adapte>>Enable.
if doesn't work try to uninstall the Wireless NIC from the Device Manager, go to Device Manager>>Network Adapter(expand)>>Right click on wireless adapter>>uninstall.
once done, click on Action Menu on the top and click on Scan for hardware changes. It would automatically detect the wireless card.
then try to use it, it should work fine :)
Regards,
Askari
[email protected]
SOURCE: My Vostro 1500 will not turn on anymore...help please!
Reset/replace the Ram/memory. Sometimes faulty and failing ram can keep a computer from booting up. If you have 2 sticks, take one out and then try to boot, then try with just the other stick. The flashing caps lock icon means a general failure, though it is most commonly associated with the motherboard.
SOURCE: mouse on my dell computer is lock up.
You could unlock it from, dell touchpad icon (you will find it beside the clock in the bottom right),after you open it you will find options for external mouse and such that, you will know your way for unlocking your touchpad.
