Just got an old PVQ-M2509. The Color seems to fade as it operates and opening the menu darkens the screen almost completely.
SOURCE: Panasonic OMNIVISION VCR Combo 1999 PVQ-M2509
the tv has a intermitent problem in the power supply.or related circuit have a tech repair on your set it is repairable it could be some lose soldering due to your explanation good luck
SOURCE: I am looking for the direct tv remote code for tv
Hello
Four digit universal remote code for Panasonic TV-VCR combo are:-
0374 0381
Three digit universal remote code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Direct Code Entry
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
