Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer Logo
K
Kelley Orlaska Posted on Nov 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Samsung VRT Front Load Washer. In the area where you add the softner, it keeps ending up with water in after each load. I have cleaned the entire drawer and it is still doing it. What do I
It is WE357. At least that is what the book says. I think I have done every cleaning that it requires. I am not getting any warning sign. It just keeps filling up with water and when I go to the next load it is full of water. Thank You
  • kimk
    kimk Sep 15, 2015
    mine has done this intermittently From Day 1. When it is full of water, it appears to be water after it flushed the softener. When I open and shut the drawer, it empties into my next load of laundry. SOoo.. my solution is to repeatedly open and shut the drawer for each new load before adding detergent and softener for THAT load.
    Since it has done this since Day 1, and the washer is very new, I am presuming nothing is clogged. There is something wrong...
    While I am here, I am NOT liking the switch to front loader.
rcbeltz
Level 2:
Scholar:
  • Expert 85 Answers
  • Posted on Nov 05, 2014
rcbeltz
Expert
Level 2:
Scholar:
Answers
85
Questions
0
Helped
41847
Points
281
I believe that you might have a clogged or damaged "siphon cap" that covers the fabric softener/bleach compartments. This cap should allow for the liquids placed into these compartments to drain when scheduled in the wash cycle. It should also allow for water that is used to rinse these compartments to drain. If the siphon cap is blocked it would slow (or stop) drainage from these compartments.
CLEANING THE DISPENSERS
The automatic dispenser may need to be cleaned periodically due to laundry additive buildup.
1. Pull the detergent liquid holder out of the detergent compartment.
2. Remove the siphon cap from the fabric softener and bleach
compartments.
3. Wash all of the parts under running water.
4. Clean the dispenser recess with a soft brush.
5. Reinsert the siphon cap and push it firmly into place.
6. Push the dispenser back into place.
7. Run a Rinse+Spin c ycle without any load in your washer.
John Sweeney
Level 2:
Habit-Forming:
New Friend:
  • Expert 77 Answers
John Sweeney
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
77
Questions
5
Helped
14362
Points
224
The nly thing i can think of is the washer level?
mollie
Level 1:
New Friend:
  • Contributor 12 Answers
mollie
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
2625
Points
38
I know someone that had that problem with their LG washer. repairman could not fix it. one day it just fixed itself. hasn't filled with water since.
5 Related Answers
vickyc
  • Posted on Apr 22, 2008
SOURCE: Samsung Front Load VRT
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
Anonymous
  • Posted on May 20, 2009
SOURCE: Door won't open on Samsung washer
Your water pump probably has debris in it. Remove the back center cover. The water pump is right there. Thread the drain line back through the machine and put the end in a bucket on the ground, most of the water will drain. I used towels to deal with the rest. Remove the water pump and open it up, I found a quarter. Reinstall and if you found debris the machine should work. It took me 1/2 an hour to do this, not worth calling for service.
Anonymous
  • Posted on Sep 03, 2009
SOURCE: filter
I have a vrt ... I hope this helps.... Take of that little door on the front. Have a bucket or bowl ready. Bring down that little black hose, turn the white cap around and pull till it comes off. Drain into the bowl, turn the white filter cap counter clockwise to release some of the suction and wait till the hose stops draining. Remove cap, clean under running water w/ toothbrush. Manual says to make sure that the interior is free of anything (I wiped mine out) and then put it all back together again. Good luck
Anonymous
  • Posted on Jan 23, 2010
SOURCE: samsung vrt washer will begin cycle but get so far
You might have an object jammed in the pump housing. First thing you must do is to unplug the machine from the power outlet.You will then need to remove the back panel of the washer to access the pump. Disconnect the wiring from the pump and remove the two hoses by compressing the two clamps. ( Be ready for water to pour out of the hoses) Remove the three mounting bolts that hold the pump to the frame of the washer and remove the pump assembly. It is easier to work on the pump if you remove it from the mounting plate. Remove the three screws that hold the impeller housing to the pump motor. Seperate the two parts being careful not to damage the rubber o-ring that seals the unit. Inspect the impeller housing for any debris. (I found a nickle blocking the outlet port in mine). Remove anything you may find and reassemble in reverse order. The machine should reset itself and run as normal.
Anonymous
  • Posted on Jan 22, 2011
SOURCE: My Samsung WF218ANW/XAA front load washer will not
lefever352, I am currently trying to solve this same issue on the identical model. I removed , cleaned, and re-assembled all the water tubes and the entire pump assembly. The pump works but for some reason it is not priming into the drain tube. The pump assembly appears to have a diaphram over the outlet opening and it it looks like this might be the problem. I am still hunting the solution, BUT so far the above actions have to resolve our issue. I hope perhaps Fixya can help.
I have a samsung front load washer and the fabric softner is not being released. How do I fix it
clean soap drawer with bleach put mech on final rince prog no clothes in mechine and let it go through rince program
Why is my Samsung VRT Steam washer holding water in the detergent/softener dispenser?
the soap, bleach and fabric softner get dispensed by opening a water valve to the dispenser to flush out the items. They then flow to the bottom of the tub. Not all of the water comes out for various reasons, but the important information is that it is seldom critical to performance. If you want to pursue it, check dispenser (take it out) and clean it well. I assume the machine is level.
1helpful
Why does My Samsung VRT front loader leave the soap dispenser full of water at the end of the wash cycle. I have to empty it in order to add detergent for the next wash cycle.
there are 2 components to the soap dispenser, 1 using liquid soap has a little tub that you dispense soap into and 2nd you remove the tub when using powder soap. I assume that you are talking about the little tub is filled with water. How this works is by adding water to the tub the level rises and siphoning empties the little tub. If any water remains it is due to water being added after the little tub has already emptied. That is not a big issue and will happen. Just empty the water or add some water to start the syphon process.
Samsung vrt washer
The dispenser drawer needs taking out and cleaning, needs to be done more frequently in hard water areas. It will slove the problem.
2answers
Why is water level low for Samsung VRT Top-Load washing machine
You may have to get someone to change the water level that's at the top of tge washing machine...
I have a samsung vrt washer. I have a load of clothes in and it says that it will not drain and to check the filter. I opened the hole on th ebottom of the washer and water is coming out everywhere HELP
use a wet dry shop vac and attach it to the end of the drain hose to remove most of the water then as you unscreww the cap again you will have a small amount of water coming out just keep using you shop vac until all the water is gone then checdk the drain pump
19helpful
2answers
Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
