I figured it out.... I was inspecting everything and the clicking noise went away when using the water dispenser... So I changed the water filter and the noise is gone. Hope this helps someone else.I figured it out.... I was inspecting everything and the clicking noise went away when using the water dispenser... So I changed the water filter and the noise is gone. Hope this helps someone else.
ALso the same noise is from out pool auto filler... it has a float in it looks like the old toilet bowl floats that triggers the water to turn on and fill the pool up to the required level. I noticed when I went outside that the noise was the same tempo. lolALso the same noise is from out pool auto filler... it has a float in it looks like the old toilet bowl floats that triggers the water to turn on and fill the pool up to the required level. I noticed when I went outside that the noise was the same tempo. lol
You can't post conmments that contain an email address.
What you are hearing is the fresh food damper. It sounds like it stuck open or stripped. You should have a tech look at it. It could stick closed and make the fresh food section too warm. Ihope this helps.
Your condenser fan underneath the unit is probably making the noise and is not turning fast enough. When that fan don't work when the compressor runs you get the heat in the center divider and possible loose cooling efficiency.
The clicking noise may be the overload located at the compressor. If so the compressor start relay, start capacitor and overload may need replaced. Have you noticed any change in cooling or freezer temperatures? Sea Breeze
there is no suction system. flush your defrost drain tube with boiling water and a turkey baster. should get some pretty nasty sludge out and sound will go away.
