Try a different remote control unit. Make sure the batties are fresh. Make sure that you are close enough to the tv. Make sure nothing is blocking between the light senser and the remote conrol. Make sure the light senser on the tv is NOT being blinded by direct sunlight. there are normally two ways to program a remote by the manual, one is automatic the other is by code. you could also just order another remote control that came with the tv.
Testimonial: "Thank you for the suggestions. Tried all that without success. Will see if I can get another remote from NEC. Cheers Yvonne"
SOURCE: moxi remote control
The "universal code" 9910 is just the first step in doing a program search. Hold down the MOXI and OK buttons simultaneously until you get the double blink. Then enter 9910 and it will blink twice again. Then begin alternately pushing MUTE and the up arrow (above the OK button). Pushing the up button effectively cycles through the codes and pushing MUTE tests the current code that it is on. Do not go too fast because when you finally push MUTE and it actually mutes (or unmutes) your TV, you must push the OK button to store that code. I just performed this procedure and my first positive code that I stored only affected the mute and volume settings on my TV and would not turn the power on or off. If this happens to you as well, repeat the above process and just skip over the first positive you get until it mutes (or unmutes) your TV again.
SOURCE: NEC model PX42VM2G service manual
You can search this database for the service info you seek about your tv here:
http://www.samswebsite.com/photofacts.html
Most service manuals with schematics cost about $27.95 for the PDF
version of it, otherwise the paper version is about $15.00 more for
handling and shipping.
You will need the chassis number of the unit in question in order to search for it. I hope this helps!
Good Luck!
Rich Lilja
SOURCE: REMOTE CONTROL CODES FOR ASTAR TV
Have you tried a Code Search with your remotes. If that does not work try calling or emailing Astar they may be able to help.
Astar Electronics
Tech Support:: (626) 851-2528
[email protected]
www.astarelectronics.com
SOURCE: no codes for remote verizon fios control of tv came with tv or are listed for RC1445 302/oob manual
for my tru-tech i used the auto code finder on the Fios remote instructions it didn t take very long, I can t say the same for my memorex tv though.
SOURCE: need code
hi i have a baird or42bafhd tv and iv lost the book and need to no the specific features could you please help me
NEC TV are
0170 0587 1170 0036
0320 0455 0009 0374
0217 0037 0556 0011
0704 0499 1704 0661
If none of these work, the manual for instructions on code searches can be downloaded at
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/one_for_all/urc3415-manual.zip&area=other
Please rate this solution. Let me know if you have any other questions or comments. Thanks.
