Jojo Posted on Nov 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
"It is time for the schedule inspection of the device." said in my Bizhub-283.How can i remove /reset it?
I already check the Counter-> [Life] and reset some parts.
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Apr 02, 2020
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913028
Points
11959
Did you replace them????? The machine uses the counter to determine certain voltage assignment to those parts so if you say you reset the drum counter to Zero then machine will assume it has a new drum and assign the required voltage for a new drum since its not a new drum because all you did is reset the counter with out replacing it ,you get bad copy issues codes and issues.
5 Related Answers
Anonymous
  • Posted on Jan 23, 2009
SOURCE: need to reset display counter/meter on a bizhub 750
If your are speaking of the total counter of the machine, the main counter when you press the "utility/counter" key this can not be reset except in the case of replacing the main board.
Anonymous
  • 13 Answers
  • Posted on Mar 05, 2009
SOURCE: how to reset manualy the counter on epson d68
Manual instruction Resetter Printer Epson D68
  1. Switch on printer
  2. Open auto.bat to set the date to 19 June 2006
  3. Run adjprog.exe from the extracted folder
  4. Click accept
  5. Click particular adjustment mode
  6. Go to maintenance then Select waste ink pad counter then click ok
  7. Click on “check button till its done then click on initialization button then click on finish button
  8. witch off printer for 5 secs then switch on again
  9. After you reset succesfully, you can change the date back to normal.
Please rate my solution after reading. Thank you
Giamma Giamma
  • 12 Answers
  • Posted on Mar 20, 2009
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
Anonymous
  • Posted on Jun 03, 2009
SOURCE: How to reset waist ink counter
help me
i have epson stylus photo r290 printer
its showing
Parts inside your printer are at the end of their service life. See your printer documentation
plz help me
my id is
[email protected]
Anonymous
  • Posted on Jan 02, 2011
SOURCE: reset lamp life counter pt-50dl54j
To reset the lamp timer, turn the TV on first. Now hold VOL DOWN on the TV and MUTE on the remote until a message appears on the screen about the lamp timer being reset. Make sure the remote is pointed toward the TV to receive the signal.
Please show me how to reset drum error for Konica-minolta bizhub 20
Bizhub 20 drum reset Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately. Make sure that the machine is turned on. Press Clear or Clear/Back on the control panel
Konica bizhub 283 photocopier error code c9401
FIRST, if this code comes back. Have a technician look at it the exposure lamp the bright light under the glass is bad or the board controlling it.
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Bizhub c350
Before replacing the IU select Utility - Meter count - Check details- Stop 00 Stop 01,enter 00000000 END,select Tech.Rep.Mode - Counter - Special parts counter-PC life.Press the Clear key to clear the counter value.Select IC life and clear the counter value.Turn OFF the copier and remove IU unit.After installing the new IU unit select Tehc.Rep.Mode -Function-F8 and press START.After 2 minutes the developer is initialized to make a copies. fcf3fced-96eb-4483-840f-8de548aa8045.jpg 378b39ea-2f19-4cf6-887c-617430da4931.jpg
How to do a trouble reset
turn off the machine then hold utility counter down turn the machine on in the upper right hand corner of the touch screen you will see a black dot that means you can let go of utility counter then it takes you too trouble reset hit it it will have an arrow that points down to ok reboot machine
Bizhub 283 trouble code 3423
if after this procedure code come back replace the fuser, attempt again machine my catch on fire that would ruin a perfectly good day
1.
Always go back in and double check the PC life counter after the reset before F8. More than once the PC Life did not reset on the 1st attempt (other counters do reset 1st time) Take a quick look see.
1helpful
Bizhub 283 error reset devloper value
You must need replaced a old developer.Before instaled a new reset developer counter or image unit counter in special parts counter.
1helpful
2answers
How do you reset the life of the transfer unit on the Bizhub C250
Yes,
Bye.
2helpful
2answers
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
