I buy 2 mobile Nokia 6700 slide in middle east Doha Qatar. Both the lcd screen become black (big dot. The cover to open usb connector easier to broken.
SOURCE: nokia 1600 problem
try the below given jumper settings,it is applicable only if the board print is available
SOURCE: LCD for Nokia mobile 5310 is required, please let me know the source in Lahore Pakistan
If the screen on your 5310 is dead
or the backlight is not working, you can buy a replacement 5310 LCD and
replace it yourself. A new Nokia 5310 display Screen costs about 20 dollars from
ebay.
I wrote a detailed guide to help you put in the new Nokia 5310 screen. Check it out at the following link:
Nokia 5310 LCD Screen Replacement
Hope that helps
SOURCE: Nokia N95 LCD screen goes off/loses power when I
The problem with the LCD of your N95 is associated with the flex. This is a common problem to all flip up and slid up phones. I will advice you to take the phone to a technician for proper repair.
SOURCE: Nokia 6300 LCD screen broken
DO IT YOUR SELF. SAVE MONEY:
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
SOURCE: Hi my n95 LCD display
I have the exact same problem.. New LCD arrived today but i only get a white backlight.<!-- from fixya rte -->
